Grading New idea for plow blade - what do you think?
   / New idea for plow blade - what do you think? #11
thanks all.
I am really not sure the lifting capacity of the bucket. Its somewhere between 900-1100lb. I would need to check the manual or search around this site.
I was going to say the front bucket quick release is an option but after second guessing myself i checked the JD site and it shows both FEL for that machine have the quick release bucket(anyone can correct me if im wrong), however i opted for the 200CX FEL since the frame is also quick release. The 200X FEL is none removable. I believe list price the CX loader is $500 more then the X.
here is a video of how fast i can change between bucket and blade. Once i add the hydraulic tilt it may take another min to hook up.
right click and save to speed up viewing-
http://www.speedfreaks-ct.com/uploads/MVI_1198.AVI
   / New idea for plow blade - what do you think? #12
Like the man said .... "that is slicker than snot". I have always been used to larger equipment (Big CAT and JD end loaders that had quick release buckets on them). I really don't understand (other than corporate cheap a-- tight wads who care more about sales and expense savings than functionality) why more manufacturers offer these things. Your video will be a real eye opener for anyone who has never used one before.
Keep building more things to hook up on it!
BTW I tried looking through the JD web site for the capacities, but the longer I looked, the more of a headache I got. They may build nice tractors and I always thought as myself as both fairly intelligent and computer savvy, but after wandering around their website for a while, all I wanted to do was scream!
   / New idea for plow blade - what do you think? #13
i agree, the JD site is horrible and their operators manual is not much better. I just looked through both my manuals on the tractor and FEL and i could not find lift capacity anywhere.
   / New idea for plow blade - what do you think? #14
bx24 said:
Purpony
- What is the FEL lift capacity on your 2320? (ish)
The published lift capacity of the 200CX FEL on a 2320 is 899 lbs at the pivot pin to max height and 1129 lbs at the pivot pin to 59"
   / New idea for plow blade - what do you think? #15
Great idea, these things are getting like Swiss Army knives, I got some good ideas looking at your work , maybe this will do some thing for you.
I almost finished this today, tried it a little and seems to work great, but after I finished it I started thinking I wonder if anyone makes an adaptor plate to go from I-match to JD front quick tach, I probably could have made one with a little more time and material, would have to start with some kind of box frame like yours, that way I could put any front accessory on the back, yours is the opposite now you can put any rear implement on the front.
I like things that have multipe uses.
   / New idea for plow blade - what do you think? #16
thanks for posting, I saw your post about that the other day and made me start thinking, if i welded some brackets on the back of my frame i could put the frame on my 3point and use my forks on the rear as well!
   / New idea for plow blade - what do you think? #17
try these locations on the Deere Website
Go to these websites and select the appropriate tractor for the list of tractor types.
300cx Loader
Select Product
200cx loader
Select Product
2021 Ford Mustang Mach-E AWD SUV (A55853)
2021 Ford Mustang...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2019 Nissan Versa Sedan (A55853)
2019 Nissan Versa...
