New House Build in the Country!!!
   / New House Build in the Country!!! #413
Nice. Hope you won't have to move again for a long time.
Haha yeah - I'm pretty sure that we will be here a while.
They were out working on the kitchen in the garage apartment today. It looks great!
   / New House Build in the Country!!! #417
Is this showing that the house water pressure is around 170 psi???? That seems really high - especially considering that the water line is over 1300 ft from the tap....
Unless you have a well, you could be in an unregulated zone as I once was in Los Gatos, CA if you're on a utility service. It's not all that uncommon. I had to install a pressure regulator at the water feed to the house. You want to set it for something around 50 PSI to your house plumbing but I like 60. They cost something like 50 bucks.
   / New House Build in the Country!!! #420
I find it bizarre that the put the cabinets in and the trim up before the walls and trim were painted. That just seems backwards. I know on ours, the walls were painted before the cabinets and trim. Of course, we had stained trim and not painted, but still, the guys that built our house normally spray the painted trim before they put it up.
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2152 (A58376)
2152 (A58376)
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
2019 Takeuchi TS80V-2 Rubber Tire Skid Steer, PIN# TKV80201102, Deutz Diesel Engine, Joystick (A59076)
2019 Takeuchi...
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
