New House Build in the Country!!!
   / New House Build in the Country!!!
Eddie,
I believe it was done with basic chalk. It's an outline of the entire crawl space. It identifies where piers need to go.
   / New House Build in the Country!!! #102
Thanks, I see that now. Never done a pier and beam foundation from the beginning. I've been on a few jobs where I built the floor once the foundation was done, but only a few. Around here, most of our foundation problems are with older pier and beam homes where the weight of the house has been too much for the soil underneath and there is some settling. My guess is they didn't go deep enough into the ground, or wide enough to support the weight of the house. I never try to fix those things, it's more then I want to get into.
I will take some pictures after work. They should be digging as we speak.
Here are some pictures from this afternoon... the last picture is the detached garage.
uploadfromtaptalk1453830155224.jpguploadfromtaptalk1453830165297.jpguploadfromtaptalk1453830175211.jpguploadfromtaptalk1453830186233.jpguploadfromtaptalk1453830199977.jpg
Here are a few pics from this evening. Inspector will be out tomorrow - concrete should start flowing tomorrow too (assuming that we pass inspection ;) )
uploadfromtaptalk1453847466614.jpguploadfromtaptalk1453847480737.jpguploadfromtaptalk1453847490229.jpg
They started on the block today...
uploadfromtaptalk1454090103296.jpguploadfromtaptalk1454090103296.jpguploadfromtaptalk1454090319112.jpg
   / New House Build in the Country!!! #109
Exciting times.
I remember the 2 homes we had built.
Im thinking about things that I should do during the build process. I already ran extra electrical lines while the trench for the water line was still open.
I plan to pre- wire for surround sound and CCTV. I also plan to upgrade all of the bathroom vents to ones with heaters.
What are some things that you did - or wished you had done in your house?
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
CASE IH 7" X 7" FOLDING TOOLBAR (A58374)
CASE IH 7" X 7"...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
Deere 310L (A53317)
Deere 310L (A53317)
CASE MXM 190 (A58214)
