New Home Build
/ New Home Build #21
Our house build is over $300/sq ft. This is with some nice finishes (3/4" hardwood floors, soapstone counters), but a lot of it is the rise in cost of materials and labor. The only thing that seems to have gotten cheaper in the past year is lumber.
Our builder wasn't very good in guiding us on where the costs lay and what makes sense to try to cut and what is "cheap". We've learned some as we've gone along:
* 2nd floor space is "cheap" as it doesn't increase the foundation and roof size. 1st floor space is more expensive in this case.
* Corners on the exterior add complexity and thus cost
* Many things (for us) are priced by sq ft: electrical, paint, some of the trim.
* HVAC is totally up to you. We are paying 2x the original estimate for inverter heat pumps vs single-speed AC + furnace, even with a lot of work (and cost) gone into additional insulation and air sealing. We could have just gone with a pretty basic 16 seer system instead
* Metal roofing (standing seam) is really expensive right now. Almost 3x what a good shingle roof costs
* "textured" hardie siding was considerably more expensive than the "smooth" siding (still no clue why)
* Brick facade on the water table is cheaper/easier than stone. The material costs may be similar, but stone adds complexity in several other areas we're learning.
* You may not realize when you're specifying something non-standard (aka "custom") and price goes up a lot more. We've found it helpful to ask for the price of what we want, and also something more basic to get a sense of this (we're on a cost+ contract)
The upside is it's pretty cheap (comparatively) to make improvements to lower the operating cost for the house - 2x6 walls instead of 2x4 for better insulation. Basic air-sealing details (tape the OSB sheathing seams, for example).
The time to complete certainly can be hard to complete, as weather, product availability, and contractor schedule are all factors right now, at least in my area. It's better than it was, but we've still seen long lead times and some down time waiting for contractors to free up/be able to make it out
/ New Home Build
I can see your frustration, and it seems to be that you don't have a comparison you can trust....don't even know standard pricing for standard levels of construction.
And I'm not as much help as I wish I could be because my situation doesn't translate well. We spent way too much time and took way too long...and had an absolute wonderful time doing it.
Do you have detailed drawings of what you want to build? You didn't say, but that is the first step.
I paid $10K to have detailed architectural drawings of a possible house done and stamped.... and then went over each area of the proposed construction with a spreadsheet and a builder friend making estimates and pricing options. Yes, I paid him thousands for his time and it was worth every penny.
And no, I didn't build that house. I might have, but instead, I used what I learned to draw up what I really wanted.... a large open house that I could grow old in & enjoy.
So I'd say you need to have or find or hire another set of eyes - someone who knows building in your area - and the two of you need to go over the drawings and put numbers to them.
So Let Me Throw it Back to Our Fellow TBNers... and ask them how they got their estimates?
rScotty
Yeah, we have to have Architectual drawings to build in our area. We had to change them a couple of times due to building codes and new set-back requirements that weren't an issue when we started but apparently a major issue. But now we have our final design. I have spoken with a retired builder (I wish he was still building) what gave me the range of $175 - $225 per square foot. The reason for that range is he doesn't know all the current cost of materials which some things are down and some are up. I also talked to another guy that only does remodeling and he feels that is also a good range. I am ok with that amount but not $250 - $300 sf.
I welcome all input because I Truley have no idea on new builds.
/ New Home Build #23
Having completed drawings is huge. I think our completed drawing package came to maybe 12 or 20 sheets. One each 24"x36" for all elevations, int. walls, foundation, floors, framing, plumbing...etc. Once you have that you can really get to work. You are now asking the right questions at the right time.
OK. It sounds like you have something that a retired builder can use to talk about - that is wonderful.
Do you think you could hire him for a short week to go over your project & then discuss it in detail? It helps that you aren't shy about being naive. Most learning takes place in the first couple of steps.
You could ask him, and let him decide if some real study with him would be doable or worthwhile.
Everything that drumminj says in #21 above is right on. Like his, our build was also custom and over $300/sf so not directly comparable. Costly in spite of wife and I working on it - I did the well, in-floor heat, & water treatment - she did hundreds of hours of sanding, varnishing and buying.
Pay special attention where drumminj says, "The upside is it's pretty cheap (comparatively) to make improvements to lower the operating cost for the house - 2x6 walls instead of 2x4 for better insulation. Basic air-sealing details (tape the OSB sheathing seams, for example)."
That is so true. The things that count are often real bargains,: Double fastened rafters & sill plates, thicker walls with more insulation, wrapping and taping everywhere, battens instead of staples in the atttic insulation, double thick door/window jams. Treated lumber deck support, cement board soffits & fire blocks, insulated stove pipe....... the list goes on and on and each one is likely less expensive than an upgraded refrigerator for the kitchen. But it takes a professional builder to mention them. Your builder friend will have his own list of things he did to his own house.
The key is that none of those things can be added later except the refrigerator.
rScotty
/ New Home Build #24
Thankfully We have never had a tornado or a hurricane hit. Although in 1972 when a hurricane came up the coast and went inland in NY there was a majorr flood but it never made it to the house. Although the property is elevated h
I am asking for details in their bid. The issue I am finding is the allotments for the foundation, electric, plumbing ect. are all over the place. So I have been breaking what bids I have so far to a price for square foot. What I am having an issue with I don't know construction prices. I have no idea if the foundation should cost me $50k or $75k. HVAC $20k or $50k. The big range is the allotments for kitchen and baths. I do know you can spend a fortune on them.
I have also been given a time frame to complete once started 6 months or less to over 8 months. So I am just trying to figure what the average overall price per square foot currently is. I know I should be looking at current low end about $200 and higher end $250 per square foot. But based off the 3 prices I have received back they have been $225 to over $300 per square foot. I just don't understand how there can be such a range. I have visited a few homes they have already built and they all look great and the current home owners raved about the builders. The only issue I found with the $225 per square foot company is they can't start building until next year and they have the lowest allotment for the kitchen.
I can’t speak for your area but I have but 9 houses on the side for people the final price depends heavily on many variables like flooring and countertops. With metal roofing and siding being popular now that is another variable. The last house I did had relatively expensive granite and a metal roof with the particular septic needed for that lot it came In around $175. Per square foot with a full basement and well. I am getting ready to break ground on my own home built ICF I’m not going to mention the price but it’s going to be around that for 2400 square feet with well and septic. I am not taking any consideration to concrete prices into this because I know it’s going to come in higher than what I originally figured. Also the 1200 foot driveway with almost 900 tons of stone isn’t in that price
/ New Home Build #25
There are too many variables for a conclusion on an Internet forum.
Build what you want. Swallow the cost p/sq ft.
Very few people will tell you the truth about their costs anyway. :)
/ New Home Build #26
Huge +1 on this.
I'm sure it's different based on region, but the impression I've gotten in my area is builders are very short-sighted and focused on the immediate task/stage and really don't look ahead to have an overall plan or avoid what would be obvious issues/conflicts if they thought about the intersection of framing/insulation/electrical/hvac/plumbing all at the same time. As an engineer, this has driven me crazy.
Before you break ground, have your hvac and insulation planned out - duct size, register locations, return locations and size, etc. Do you need floor trusses to accomodate ducting? Energy heel trusses to allow full depth of attic insulation over the top plates? Yes, you may need to adjust slightly based on actual framing details, but you'll know where the laminated beams are up front so you can plan around them, etc. Do you have a range hood? Where does that vent/how does that work with the framing? Big enough range hood (>400cfm) to require make-up air? How/where is that piped in?
Having these thought through and planned up front will save you money in re-work/re-framing-etc. Not $50/sqft in savings, but several thousands of dollars in my case (in extra cost, as these things were not considered and we had to cut/modify some trusses as well as floor joists).
If you're interested in the efficiency/comfort side of things as rScotty and I are touching on, happy to recommend some books and other websites to read up on.
/ New Home Build #27
My impression is his quest is more for information than conclusions. Maybe I'm wrong.
That is well said: To build what you want and not let cost p/sq ft be the ruling factor
Satisfaction lasts far longer than the memory of the costs.
- Shouldn't that apply to buying tractors too ?
In our case - maybe in many cases - building costs are not deliberately false, they are simply hard to figure. While building we ran across crazy bargains and to also made on-the-fly expensive changes. Most TBNers are also do-it-yourselfers. How does one figure his own time?
Building a home should be an adventure. If your build is like ours, you will make some expensive mistakes and find incredible bargains.
rScotty
/ New Home Build #28
If I was to build another house I would be using rock wool for insulation, fire proof, sound proof and great insulation! It will cost a little more but its well worth it.
willy
/ New Home Build #29
I have used mineral wool/rock wool. It is a good product but some feel it is more itchy than fiberglass.
/ New Home Build #30
rScotty
My wife is picky with numbers. That's always an asset. She counted everything.
For example, on the internet an owner might quote $125 p/sq ft. I might ask, did that include your sewer system? They will 99% of the time say, no that was separate. Not in my wife's math.
Not calculating "everything" including graveling the driveway is how over runs occur.
Very rare for an owner to ask for a completed cost estimate. If they get one they rarely use that builder because he was too high. Very common for them to use the cheapest bidder, then over run making up for all the things he didn't factor in his "cheapest" bid. :)
/ New Home Build #31
willy
Insulation and quality windows/doors are the cheapest part of a quality build.
/ New Home Build #32
She is right of course. That's how to do it. But when she starts doing that, the conversation shifts more toward the total cost of construction for a custom rural house. That is going to be a whole lot different than trying to compare house prices using dollars/sq ft. Rural construction differs from suburban.
I guess you could compare the rural house itself without any extras to a suburban house. But the rural house also has to budget for a whole lot of extra expenses that don't fit well with SS/sq.ft. calculation.
Perhaps the only time that $$/Sq ft. is really a useful measure for directly comparing costs is when comparing nearly identical houses in a suburban subdivision. In a subdivision the house itself my differ, but everything else - utilities, lawn, garage, & lot size is all the same.
Unlike rural houses, suburban houses don't have wells & water treatment, septics, back-up generators, long driveways, alternative heating, large gardens, wood lots, outbuildings, detached garages, ADUs, Tractors! - and all the rest that go along with rural living.
But by being picky with numbers anyone can still compare costs. It's just more complicated than $$/ft.
rScotty
/ New Home Build #33
Agree on this. Suburban homes pay a monthly fee for infrastructure services. For a rural build, you need to build those in up front and then just pay the electricity to operate (well pump, septic, etc), which does bring up the $$/sqft for the build. And don't forget running electricity to those outbuildings, the larger electric service..buying and burying a propane tank...
/ New Home Build #34
Not sure I understand where this has went. :)
So suburban homes don't have to pay to hook up to the burb system?
Burb homes don't pay for electricity they use?
Burb homes don't have to pay to run electricity to their outbuildings if they want it?
Burb homes don't have to buy and/or bury their own propane tanks?
Incredible. :)
/ New Home Build #35
I'm not following you on this. Oh.... I think I see.....you are ahead of us and are now talking about monthly utility bills.
We aren't there yet. The OP hasn't built anything yet. We were discussing how to consider the square foot costs of building a house and sort of diverted into $$/sq foot for suburban vs rural building costs.
Monthly bills are inevitable, but they are not building costs. The question is, do contractors include all the right costs in their estimate of $$/sq ft. bid?
Suppose you pay (as we did) about $30K to have the utility company put in poles and wires to bring electricity to our property. That is certainly a rural building cost, but should it be considered when calculating $$/sq ft?
I think not....
rScotty
/ New Home Build #36
Incredible. :)
Around here the differences can be huge. A suburban house within the town limits has to pay about $10K for a water & sewer tap fee. Hooking up to those services is part of the building cost.
Outside the town limits the water and septic costs are more like separate projects. That's all I was saying. Agree?
/ New Home Build #37
Incredible. :)
If you're referencing my post, let me see if I can clarify my statements....
1) Yes, suburban homes have to pay for electricity they use...hence the "electricity to operate" referenced above. Also the water they use, at higher rates than the cost per gallon of water from a well (storm drain fees, etc).
2) Rural houses without city infrastructure have to pay to drill the well and put in a septic field, which costs a lot more in construction, whereas those with city infrastructure "just" need to pay to connect to the existing infrastructure, which is generally less expensive than the cost of the well + pump and septic system.
3) Suburban homes are far more likely to have natural gas lines to connect to, vs needing a buried propane tank. Again, connecting to the existing gas infrastructure is far cheaper than the cost to buy and bury a tank (Esp. at current prices!)
4) Suburban homes are less likely to have outbuildings (generally smaller lots), and thus no need to run electricity to them, the cost of which is likely rolled up in the initial electrical install, raising the $$/sqft for the initial build. Yes, if the suburban home has outbuildings and wants to run electricity to them, I'd expect the cost to be similar.
All of which is related to the side topic of comparing cost/sqft on builds as it depends on many factors, one of which is whether it's a rural, suburban, or urban build. I was just ageeing with rScotty's comment in this regard, and adding some more details based on my experience building.
Sorry for the confusion and addition to sliding the thread!
/ New Home Build #38
Yep. I agree.
My wife, on the other hand, separated this way. If we had not built the house would we have that expense? If the answer was no, then it goes in the cost of the build pile. :)
/ New Home Build #39
No apology necessary. Good discussion of things a first time builder won't think of.
1) I'm on a rural electric coop. I don't know what my rate p/kw is. I have a transformer box and meter pedestal in the backyard. Cost me $1,250 to get those set. Then I buried wire to my shop and house. Short runs. I'll guess another $500.
2) I'm on a rural water district. Cost me $2,500 to get a meter set. Then I ran a buried pipe to my shop/house. Guessing another $500. Septic is a lagoon which I built. Guessing cost to plumb to it at $400.
3) No NG. Bought a 1000 gallon propane tank for 1,000. Guessing $300 for hookup. This past year I used 1050 gallon of propane at $2.15 p/gal.
4) Again, with my picky book keeper wife, if the outbuilding has electricity because the house was built, it counts. :)
/ New Home Build #40
That's a lot cheaper than what we're seeing. Current quote is $8k for a 1000gal tank, installed. Cost us $2300 to run the copper from the road to the transformer pad. Total (conventional) septic cost is estimated to be about $30k (that work should be starting soon). We do have to pump uphill to the field.
When did you build, ovrszd?
