New Holland's useless cupholder, solved...
   / New Holland's useless cupholder, solved...
Good to know that when you catch your cup holder on a massive tree your going to tear your fender off before you damage your beverage or cup holder... :p
My trees are either fruit trees, nut trees or inaccessible by tractor. The fruit and by trees I'm very cautiuos around those.
   / New Holland's useless cupholder, solved... #22
If the OP is catching his cup holder on a massive tree, he's likely to be doing something wrong besides building an indestructive cup holder. :eek:
   / New Holland's useless cupholder, solved... #23
I made a cupholder out of short piece of 4 inch PVC pipe and a machined plastic piece that fits perfectly inside for a bottom. I slotted the PVC pipe for to clear the handle on my 30 oz. RTIC stainless steel mug. Made a pair of split clamps to clamp it on the headlight pipe on the old C. Works awesome!
And it is white to reduce solar heat gain. The black cupholder will not keep your German Road Sodas as cold as a white one.
   / New Holland's useless cupholder, solved... #24
+1 on frozen bottle
   / New Holland's useless cupholder, solved... #25
Where's the "like" button on here? LOL
   / New Holland's useless cupholder, solved... #27
Why not just get one of these. They are awesome
Swigzy Car Cup Holder Expander Adapter with Adjustable Base - Rubber Tabs Securely Hold Large Water Bottles https://www.amazon.com/dp/B0752DZ1SB/ref=cm_sw_r_cp_apa_09U3BbMR5B8FG 20181025_085153.jpeg
   / New Holland's useless cupholder, solved... #28
3 or inch PVC end cap with piece of PVC pipe and magnet pop riveted to it. Total cost end cap $3.29 PVC pipe (scrap) 1.5" round magnet $3.19 = $6.48 Labor free.
   / New Holland's useless cupholder, solved... #29
My TC 45 New Holland came with a nice molded beverage holder as a part of the tool box. Both are very useful and the beverage holder holds either a 12 or 16 oz Budweiser in a Snuggie just fine.
The problem is, there is no room for more than one and the operator station is too small for the Yetty cooler.šŸ™
B. John
   / New Holland's useless cupholder, solved... #30
The problem is, there is no room for more than one and the operator station is too small for the Yetty cooler.��
B. John
Simple cure. Mount Mini-Fridge or full size fridge(depending on thirst) on a carry-all on the 3point hitch. Mount inverter to run fridge and maybe a Johnsonville Brat Cooker. No limit to the necessities.
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2010 New Holland TD5050 95HP 4WD Agricultural Tractor w/ Bush Hog 2610 10ft. Rotary Mower Attachm... (A55973)
2010 New Holland...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
