New Holland TN70
/ New Holland TN70 #1
crazyhorsemd
cincinnati, Ohio
2000 New Holland TN70, 1974 White 1370
Just purchased NH TN70 2WD, I always like to change fluids initially as not sure when last maintenance completed. Have operators manual but not real clear on a couple issues
1. Where exactly sure where Drain(s) plug for trans/hydraulics are. I've read possibly 3 or 4 plugs exist. Is fill pug just where dipstick located?
2. Is there a power steering reservoir or does this run off hydraulic system?
3. Is there a final drive drain plug on rear wheels..if so how much fluid does it take?
4. Any special brake fluid or just DOT 3
5. plan on fuel system / filter also...any unusual tricks I need to be aware when I go to bleed system?
Read up on oil change..that appears straight forward
May seem like overkill but when I change all initially, then I know when it's been done and done right with proper level and fluid
Thanks for any input
Nice to see a website dedicated to providing assistance and info without all the negativity and personal attacks
Crazyhorsemd
/ New Holland TN70 #2
I suggest you post in the Ford/New Holland section or as a Moderator to move your post there.
