New Holland TN60A - Can I turbo it?
   / New Holland TN60A - Can I turbo it? #11
Go for it! After many years of needing more power than my Ford 1720 (91CI) could develope I installed a turbo and couldn't be happier.
I installed a waste gated Garrett GT-1752 that came off a SAAB. The installation is clean and the tractor now has the power to handle my 60" snowblower without bogging down.
I turned the engine speed up to 2900 and the fuel up and it builds 8~10 lbs of boost. As for hp deveploped, don't know but it is significant!
I don't use the additional power for extended periods to do the job of a larger tractor but to power thru tough spots when snowblowing or mowing. As with anything how you used it will determine the overall success of the project.
   / New Holland TN60A - Can I turbo it? #12
I've always liked it when I hear stories like this of someone making something work like that 90cummins. Kudos!
   / New Holland TN60A - Can I turbo it? #13
you may have to at least change your head gasket to the turbo spec model's gasket. they are usually the first weak link.
   / New Holland TN60A - Can I turbo it? #14
No head gasket change is needed for mild hp increases, but retorquing the head would not be a bad idea.
   / New Holland TN60A - Can I turbo it? #15
Any one here of a turbo on a 1715? If so, who does it and where are they located?
   / New Holland TN60A - Can I turbo it? #16
Never heard of a tirbo on a 1715 Ford but it can be done.
The turbo on my 1720 would probably work nicely on your 1715 but may be a bit slow to boost because your engine is 81cu in versus my 1720's 91cu in.
AUCTION STARTS HERE @ 9AM (A52707)
AUCTION STARTS...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
John Deere 8400 (A53317)
John Deere 8400...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
