New Holland TN60A - Can I turbo it?
   / New Holland TN60A - Can I turbo it? #11
Go for it! After many years of needing more power than my Ford 1720 (91CI) could develope I installed a turbo and couldn't be happier.
I installed a waste gated Garrett GT-1752 that came off a SAAB. The installation is clean and the tractor now has the power to handle my 60" snowblower without bogging down.
I turned the engine speed up to 2900 and the fuel up and it builds 8~10 lbs of boost. As for hp deveploped, don't know but it is significant!
I don't use the additional power for extended periods to do the job of a larger tractor but to power thru tough spots when snowblowing or mowing. As with anything how you used it will determine the overall success of the project.
   / New Holland TN60A - Can I turbo it? #12
I've always liked it when I hear stories like this of someone making something work like that 90cummins. Kudos!
   / New Holland TN60A - Can I turbo it? #13
you may have to at least change your head gasket to the turbo spec model's gasket. they are usually the first weak link.
   / New Holland TN60A - Can I turbo it? #14
No head gasket change is needed for mild hp increases, but retorquing the head would not be a bad idea.
   / New Holland TN60A - Can I turbo it? #15
Any one here of a turbo on a 1715? If so, who does it and where are they located?
   / New Holland TN60A - Can I turbo it? #16
Never heard of a tirbo on a 1715 Ford but it can be done.
The turbo on my 1720 would probably work nicely on your 1715 but may be a bit slow to boost because your engine is 81cu in versus my 1720's 91cu in.
2021 BOBCAT T870 SKID STEER (A52707)
2021 BOBCAT T870...
CATERPILLAR 20" PIN ON BUCKET (A52707)
CATERPILLAR 20"...
UNUSED FUTURE 750 REMOTE CONTROLLER LAWN MOWER (A57193)
UNUSED FUTURE 750...
UNUSED CAPTOK BC63-60" HYD BRUSH CUTTER (A57193)
UNUSED CAPTOK...
(2) Firestone 420/80R46 Tires w/Rims (A56469)
(2) Firestone...
2021 CATERPILLAR 906M WHEEL LOADER (A52707)
2021 CATERPILLAR...
