jjaphipps22
Bronze Member
- Joined
- Jun 6, 2017
- Messages
- 60
- Location
- Fredericksburg, VA
- Tractor
- New Holland TC45S, Ford 1620-Sold, Ford 4100-Sold, Hinomoto C174-Sold, Allis Chalmers 5015-Sold, Farmall Super C, Farmall 140
First Post, so I will start off by saying hello and thank you since I have used this site many times in the past to help with issues on my other tractors. Here is my issue, I just purchased a TC45S that has been sitting for a few years and I am attempting to get this thing started but have been unsuccessful to this point. I have no fuel after the injection pump. I have ran a jumper to the solenoid (even though i bench tested it and turned out fine and confirmed it has power installed), confirmed fuel flow to the filter and fuel pump, confirmed the fuel pump (this tractor has a engine mounted pump) to the bleeder bolt. I had a similar problem on my Ford 1620 after a tear down and rebuild earlier this year and it turned out I needed to use a 12v inline fuel pump (this tractor did not have a fuel pump, it used gravity feed) to push fuel through the injection pump to bleed it and then all was fine. FYI I have tried the same thing on the TC45 and it just pushed fuel out of the injector bleed off lines that run back to the filter housing. What am I missing here? Do I need to take the pump in for testing and possibly repair?
