new holland tc25d
   / new holland tc25d #1
jeff4834
cortland,ohio
new holland tc25d
well I did it,anyway I was changing rear tail light blub and my screw driver touch the hot and ground,I saw a little spark and now nothing,no dasd lights,won't turn over.I check the fuses on the firewall with a meter all ck out ok.I don't know how to ck the fuses under the cover by the key but I know there are two of them .how do you check them.or sure I be looking somewhere else?
   / new holland tc25d #2
I don't know your model but there's been lots of threads about NH fuses. The search tool is a little cumbersome but usable.
Jim
   / new holland tc25d #3
If you have nothing at all, then I would check the 30 amp fuse located above the starter on the left side of the engine block. Open the hood, snap off the left side cover and there is an encased blade type fuse inline above the starter. Again, this is a 30 amp fuse and most owners have replaced it with a 30 amp auto reset fuse available from your auto parts store. This fuse tends to blow when you try to start with the lights on, hazards on or a combination of these. I would also check to be sure the right fuse (a 15 amp) is in the #5 (bottom) slot on the firewall box. Post your New Holland question on the NH owning/operating page for a quicker response. Hope this hepls.
   / new holland tc25d
Thanks I found it.I did what you said to do
ThANKS Jeff
Kubota L5030D 50HP Front Loader Utility Tractor (A50322)
Kubota L5030D 50HP...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2015 Ford Econoline Shuttle Bus (A50323)
2015 Ford...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
