New Holland TC24D - Low gear issue.
   / New Holland TC24D - Low gear issue. #1
keemoe
Marianna, FL
New Holland TC24D
Tractor will not move when shiffed to low gear, all other gears work fine. Has the standard trans, 3x3. Dealer said the problem was internal, any ideas as to what could be the issue? Other post on the same subject didn't get a resolution.
Does anyone have any ideas ???
   / New Holland TC24D - Low gear issue. #4
Does it act as if it is in neutral or does it pull the engine down.
Does it feel like it's going into detent or does the shifter just feel loose.
   / New Holland TC24D - Low gear issue. #5
Lets clear up the layout first. Is this a 3 plus reverse on the column and three speed ranges on the fender with low range between medium (Forward) and high (back)? If not please clear up the layout. If this is the arrangement, and it is the low range between high and medium on the fender, then it probably is an internal issue and will need at least the tranny cover removed to examine the shifter and gears.
   / New Holland TC24D - Low gear issue. #6
if it's set up like that, it could be a linkage adjustment issue. there must be a linkage from the fender to the transmission..
9000 (A47477)
9000 (A47477)
2005 Caterpillar 928G Articulated Wheel Loader (A55973)
2005 Caterpillar...
Bobcat T590 (A53317)
2012 Big Tex 25ft. 9 Ton T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 Big Tex 25ft...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
72in Forklift Safety Basket (A56857)
72in Forklift...
