New Holland TC 30 stalling
/ New Holland TC 30 stalling #1
cedar21
Bronze Member
Oak Harbor, Washington
New Holland TC 30
My New Holland TC 30 has been stalling lately. Sometimes it just dies, and other times it loses power and then recovers, or sort of surges. I have cleaned the fuel filter and bled the lines at the injectors. I am wondering if it could be the fuel injection pump, and how to test it. Any thoughts on whether I am on the right track here, and how to test the pump?
I don't think the symptoms my tractor is having are the same as described in the video. The tractor acts like it is going to die, but then recovers. Only once in a while does the engine stop completely. It ran OK for about half an hour today and then started doing the same thing again.
/ New Holland TC 30 stalling #4
Floaters in the fuel tank.?? Clogged outlet screen in the fuel tank.??
Pull the line coming out of the tank & drain into a bucket..
Does it have an on/off valve.?? either on the fuel filter or at the tank??
its not uncommon for them to work themselves to a "mid" shut off position, or get a small clog right there..
I doubt its an inj. pump problem.
It does have a shut off valve, and I have checked that. I will check to see if it has an outlet screen at the fuel tank, and also check for a clog at the shut off valve. Thanks for the ideas.
/ New Holland TC 30 stalling #6
u got slime/algae floaters sounds like/fuel restriction
I am not able to look into the tank from the top of the fuel tank, because of how the filler tube is configured. I drained the tank and changed the fuel filter about a month ago, though did not check to see if there was a screen where the line goes out of the tank. The fuel filter did not look especially dirty. There was a bit of sediment in the bowl, and I cleaned that out.
I have not figured out what is causing the tractor to lose power and stall yet. I drained the tank, removed the fuel lines and blew compressed air though the lines. Blew compressed air through the breather tube and the fuel filter, refilled with fuel, bled the lines, and it is still doing the same thing. I did notice that the fuel shut of valve seems to be broken to where it stays open no matter what position it is in. There seems to be good fuel flow at the line where it goes into the injector pump. I have been using off road diesel that is sold at the local farm co-op. Could it be bad diesel? The tractor has had the problem off and on for the past year, but it is getting much worse lately. I have not located the filter at the tank, if there is one there.
/ New Holland TC 30 stalling #9
"IF" your tractor has an outlet filter, it would be on the end of the outlet/feed pipe connection..
Some do & some don't..
I looked at a parts diagram online, and it does not show a filter at the tank outlet pipe.
I have a repair manual for the tractor. One of the things is says is it could be is a problem with the governor. Hope not....
Could the fuel shut off solenoid be intermittently closing then opening again, but otherwise work?
I took the solenoid off and tested it. When power was applied the rod retracted as it is supposed to. I tried running the tractor but it stopped again. Bled the lines and it started again, ran fine for a bit, and started running unevenly again. I don't see any fuel leaking anywhere. If bleeding the lines fixes the problem temporarily, seems as though it must be related to air getting into the system somewhere.
/ New Holland TC 30 stalling #14
U can find a leaking line by pressurizing the fuel tank w/ compressed air.. NOT MUCH or you'll blow something..
Maybe set your compressor to 4psi.. Some people have very good luck covering the lines & connections w/ BABY POWDER..
The leak will show clearly in the powder..
Good luck
OK, thanks. I will give the baby powder a try.
Yesterday, I drove the tractor from the barn down a dirt road about 100 yards and it stalled. I got it going and put it back in the barn. Tried again later because I needed to move something with it, and it stalled at exactly the same place. Then I used it to move some manure. I made two trips, and both times, as soon as I started to dump the bucket, at the exact same place, it stalled. Could be just coincidence but seemed sort of unusual.
I may have found the problem, or at least a problem. There is a solenoid or switch that prevents the tractor from starting unless it is in neutral. The wire on the switch, that goes into differential housing, was hanging by a thread, and then fell off. So the tractor won't start at this point. I tried to take the switch out, and a torpedo looking piece came out of the differential housing and hydraulic oil was pouring out, so I reinstalled it without the torpedo piece temporarily. Is it possible that the frayed wire on that switch could have been causing the tractor to stall at times?
Edit: It may be the PTO safety switch, not the neutral safety switch.
Edit: I bypassed the switch and got the tractor started again, but it is still doing the same thing with the stalling. Have not done the baby powder test to see if there is a leak. I guess that is next. Worried it might be something more serious.
I figured out why the tractor kept stalling. The previous owner had bypassed the seat safety switch. The connections on the bypass wiring had loosed to where sometimes it was not making contact. I tightened the connections, and no more stalling. It wasn't fuel related after all.
/ New Holland TC 30 stalling #18
cedar21 you are a lifesaver. I've been nagged by this forever. I was the one that bypassed the switch. My problem was the round wheel that the seat rides on has a flat spot. Thanks for pointing me in the right direction.
