New Holland '98, model 1920 Backhoe hookup
   / New Holland '98, model 1920 Backhoe hookup #1
jim swyers
festus mo
1998--1920 New holland
I have purchased a 757c new holland backhoe to install on my model 1920 new holland tractor with a bh loader--I do not have a port on the back of the tractor----my idea is to "T" off the pressure block for the loader and run the return line where the plug is under the seat----Help I am kind of unsure if I am on the right path
   / New Holland '98, model 1920 Backhoe hookup #2
You can not tee into an open center hyd circuit.
If your FEL valve has a PB outlet, you can obtain flow from the PB adapter.
There may be other ports available.
I have finally got back to this problem since I have received a 1920 manual---I am wanting to "T" off of the operating hyd manifold block----The block has an inlet,outlet,and return--The power beyond hose goes to the inlet
and I plan on my t on the outlet for the in to the backhoe and the backhoe return to the plug under the seat
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
201707 (A54756)
201707 (A54756)
2000 Witzco Challenger RG-50 48FT 50 Ton Tri-Axle RGN Lowboy Trailer (A52377)
2000 Witzco...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
1996 Elgin Pelican Series S Street Sweeper (A55787)
1996 Elgin Pelican...
