New Holland '98, model 1920 Backhoe hookup
   / New Holland '98, model 1920 Backhoe hookup #1
jim swyers
festus mo
1998--1920 New holland
I have purchased a 757c new holland backhoe to install on my model 1920 new holland tractor with a bh loader--I do not have a port on the back of the tractor----my idea is to "T" off the pressure block for the loader and run the return line where the plug is under the seat----Help I am kind of unsure if I am on the right path
   / New Holland '98, model 1920 Backhoe hookup #2
You can not tee into an open center hyd circuit.
If your FEL valve has a PB outlet, you can obtain flow from the PB adapter.
There may be other ports available.
I have finally got back to this problem since I have received a 1920 manual---I am wanting to "T" off of the operating hyd manifold block----The block has an inlet,outlet,and return--The power beyond hose goes to the inlet
and I plan on my t on the outlet for the in to the backhoe and the backhoe return to the plug under the seat
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
