New Holland '98, model 1920 Backhoe hookup
   / New Holland '98, model 1920 Backhoe hookup #1
jim swyers
festus mo
1998--1920 New holland
I have purchased a 757c new holland backhoe to install on my model 1920 new holland tractor with a bh loader--I do not have a port on the back of the tractor----my idea is to "T" off the pressure block for the loader and run the return line where the plug is under the seat----Help I am kind of unsure if I am on the right path
   / New Holland '98, model 1920 Backhoe hookup #2
You can not tee into an open center hyd circuit.
If your FEL valve has a PB outlet, you can obtain flow from the PB adapter.
There may be other ports available.
I have finally got back to this problem since I have received a 1920 manual---I am wanting to "T" off of the operating hyd manifold block----The block has an inlet,outlet,and return--The power beyond hose goes to the inlet
and I plan on my t on the outlet for the in to the backhoe and the backhoe return to the plug under the seat
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
RV Hitch (A50121)
RV Hitch (A50121)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
