New Holland 758C Backhoe
/ New Holland 758C Backhoe #1
Rushed
Dudley
New Holland Boomer 25
I was wondering if the 758C backhoe would fit my New Holland Boomer 25.
I can't find any info if it would just bolt up or not.
The backhoe attachment has the quick connect frame with it.
Thank-you.
/ New Holland 758C Backhoe #2
I am not smart enough to go through the N.H. site and determine such info , But I do have a TC 30 with the 757C on it and the sub frame so simplest idea would be I could just take measurements here in a bit , ( need to let sun come up ) . I think the 2 most important measurements would be from side to side were your loader attaches at mid point of tractor , ( this is were the front part of sub-frame also mounts ) , and the length from that forward mount to the rear of tractor were the 2'nd mount is , basically were a draw bar would attach .
There are likely others here that can give a quicker answer , I imagine that there is not much difference between my TC 30 and a Boomer 25 as far as the Hydraulics flow , etc.. , But other factors , i.e. Weight , etc .... , are above my pay grade .
Fred H.
Thanks for the quick responce guys.
The only reason I ask if it will fit the Boomer 25 is the 758c hoe is spec to fit on the NH TC25 tractor witch the Boomer 25 replaced and my boomer is a larger tractor with 27HP rating.
On the NH website it only specs 1 hoe for the Boomer 25 and thats a new line of hoes also.
Just to follow up with this tread.
With info I got from New Holland.
They informed me that the Boomer series tractors have a differnt frame than the older tractors and the older frame mount attachments wouldn't fit cause the newer tractors are built by differnt specs in a differnt contry.
Hope this helps out anyone wondering the same thing I did.
Merry Christmas to all.
/ New Holland 758C Backhoe #6
The Boomer 25 are 27hp same as the TC the new Boomers are made by LS in Korea whereas the 1000 series and predecessors where US Built machines. In saying it won't fit would be right but anyone capable could adapt the sub frames just bear in mind that the boomer 25 should have a full length sub frame. The ones we get here in OZ fit in neatly with the loader subframe and are quite a tidy, easy detach setup hope this helps you.
/ New Holland 758C Backhoe #7
Not sure what you mean by the 1000 series, but neither Ford nor New Holland ever marketed a compact tractor built by anyone other than Shibaura until the LS deal came along. Shibaura is a Japanese manufacturer.
