New Holland 68 questions
   / New Holland 68 questions #11
When you say right or left, it is relative. Your right/left should be referenced as though you were standing behind the baler looking towards the tractor. Can you clarify?
Oops - just saw you are doing this.
To get more hay to the left, the feeder fingers need to move to the right. Counterintuitive, but gives a larger charge of hay into the chamber - the manual speaks to this adjustment. Also feed windrow into the pickup next to the bale chamber. A New Holland baler likes a good bit of hay in the pickup, just don't jam it. If you don't have heavier windrows, i.e. double raked in thinner crops, make them. Also pickup a gear to fill the pickup. Run at 540 PTO rpms.
In addition, make sure the 3 hay dogs and their springs are there and working. You should have 4 vertical triangular wedges, 2 each side in the bale chamber.
Stick with it - the 68 cam make a brick just like a new baler.
Adjusted the feeder fingers a couple more times during the second cutting and the bales are coming out great now. Thanks for the suggestions on all the different things that can prevent making a "square" square bale.
However, by the time I was done baling, it was evident the clutch needs work. Today I cleaned out the baler and lubed it up then took the clutch apart. One of the friction discs was almost completely gone-rubbing metal to metal in some spots. One disc still looks pretty good. Looks like it is simply a 1/16" piece of gasket sheet and the New Holland dealer wants $80 for a new one. Anybody rebuilt a clutch using gasket material from an auto parts store instead of using the New Holland part?
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A56857)
2025 JMR Single...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
(3) HAND TRUCK (A52708)
(3) HAND TRUCK...
