New Holland 2007 TC30 wont start
   / New Holland 2007 TC30 wont start #1
racer86y
2010 Kubota L2800
I have tried everything.The starter won't engage and fuel shutoff wont engage.I took battery cable off for 30 minutes or so and it fired up and died.Then it went back to same thing.Any ideas would be greatly appreciated.This is 3rd time in a year this has happened.The other 2 times i let it sit for a few weeks and bam,it started and ran for several months with no problem.
   / New Holland 2007 TC30 wont start #2
Can you explain "everything"?
Dutchy
Dutchy
new battery,new fuel filter,new air filter checked all the sensors and only one i could not get to show its right is the air control sensor.I plugged black and orange together but it did nothing.
   / New Holland 2007 TC30 wont start #4
This sounds like some kind of computer issue. If you can let it sit for months then have it magically work, try disconnecting the battery. Take the leads you removed and short them together. This should drain any residual voltage in your system. You may also wish to turn on the key switch at this time to ensure those circuits are drained also. After having done all this try reconnecting the battery. This may not help but it might give you more information to go on.
I cleaned both cables and both post but now as before something is telling fuel shutoff valve not to open.It spins over nicely now just won't start.
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
2021 Deere 331G (A53317)
2021 Deere 331G...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
Honda UTV (A56859)
Honda UTV (A56859)
