New Hitch for FEL
   / New Hitch for FEL #21
I sure like those receivers welded to the bucket! Since I haven't got around to that yet, I just use the hook on my bucket. I've got 3 tow hooks bolted to the top of my bucket on my BX2230. I simply roll the bucket forward and drive under the boat hitch, then place the center hook under the hitch and lift. My Baja is 4500 lbs, and I move it where ever I want. My boat is 25' long and the garage is about 25' 1"....The boat is also about 105" wide and the door is only 108"....so you can tell its a very tight fit. I've put the boat in there with my truck once and it took me a spotter and about 45 minutes of cussing to manuever it in there. Now I do it with the bota in 5 minutes by myself.....very handy, and to me a necessity!
I can even manuever it nice and close to the wall to make the most of my tight garage space. if I get the tandem axle trailer torqued sideways a bit, I can lift the front of the trailer high enough to take the weight off the front axle, then sit it back down so it will rest straight.
   / New Hitch for FEL #22
I put the tube on top of my bucket, not inside.
Big mistake. I have a couple of 4" drops but that is not enough for either of the trailers I move around. Mounting it inside the bucket will drop it at least 6" which will be much better. I won't worry about a cover for it. It will be open on the back for any material to easily slide out.
Also I was using it one day with a rope to pull a log (I know I should have used a chain on the 2 hooks) when I lifted the bucket to help the log over a bump It bent the top edge of my bucket into a shallow V.
Another day I had my small plastic utilty trailer on it on a hill. (500# gravel in the trailer) When I was manuevering the tractor to back up the hill, the trailer got out of shape and twisted the tube sideways. It also bent the 4 inch drop ball mount and twisted the coupler on the trailer.
Anyhow I obviously have a welding project once I bring the tractor home this winter.
2000 FREIGHTLINER CLASSIC (A58214)
2000 FREIGHTLINER...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
Auger Skid Steer Attachment (A56857)
Auger Skid Steer...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
2014 PETERBILT 388 (A58214)
2014 PETERBILT 388...
