New Guy with Kubota G1900
   / New Guy with Kubota G1900 #1
22R
Kubota G1900
Hi everyone. So I just swapped my 1998 Gas EZGO golf cart for this Kubota G1900 with 605 Hrs. It has the 54" deck.
I have a few questions about it.
1. Is there any source for free download of a owner's manual ?
2. Yesterday the temp gauge worked and the Fuel did not, Today it is opposite. I assume a bad connection, I have already checked the fuses they are good.
3. Oil filter ? Is the Kubota one needed or is the price the same for a AM ?
4. Deck comes off easy ? Looking at it it does not seem to bad.
5. Did all of these come with fuel cut solenoids ? This has a make shift lever attached to the throttle linkage to kill the motor
So my plan is I have 2,5 acres and I have a 60" Exmark. I plan to use the Kubota for yard work and a backup for the ZTR.
I plant to remove deck, clean it rust extend it, check spindle bearing condition and then change all fluids.
Any tips or pointers appreciated.
I will try to attach some pics.
Thanks,
22R
Thank you and I appreciate your help. I would love to one day visit Australia.
22R
   / New Guy with Kubota G1900 #4
:welcome: to TBN...enjoy.
All refresehed up now.
   / New Guy with Kubota G1900 #7
Nice! Enjoy!
   / New Guy with Kubota G1900 #8
Hi 22R! Did you manage to find a free operators / workshop manual for the G1900? I have a G1900S and need to do some work on it, and a manual would really help! At the moment I need to work on the PTO brake and adjustments to the various related springs and stops. Some guidance would really help.
   / New Guy with Kubota G1900 #9
It may have had a solenoid. Look for wiring that isn't connected to anything. I have an old G3200 which had a pull knob to stop the engine. It was factory. The rest of mine has changed quite a bit though. I'm in the process of new hose and cylinder upgrades along with a Skid Steer Quick Tach Conversion for the loader.
Oh yeah, I'm adding power steering too.
   / New Guy with Kubota G1900 #10
Regarding the fuel and temp gauges, from my experience, what happens is the needle itself just sticks to the start pin where it rests. A quick whack of the area around the dash usually gets the needle moving off the pin.
  • Good Post
Reactions: 22R
KOLDWAVE KWK14BEA1AA0 PORTABLE ELECTRIC AIR (A51248)
KOLDWAVE...
UNUSED LANDHERO LDH-KV16 EXCAVATOR (A51247)
UNUSED LANDHERO...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2025 INDUSTRIAS AMERICA FT510 5' X 10' HYD DUMP TL (A51247)
2025 INDUSTRIAS...
