New Guy...B6100E Aftermarket Gauge Install Qs..
   / New Guy...B6100E Aftermarket Gauge Install Qs.. #1
Conn
Garrard County, Kentucky
John Deere 6210
I recently aquired a B6100E with a 60" finish cut mower. The old girl needed some cylinder head work and is in the process of re-assembly at the moment with all new top end gaskets.
I want to add a water temperature and oil pressure gauge. I've located the oil pressure port, but can't seem to find a location to tap into the cooling system. Has anyone performed this task in the past and can you provide any information?
Also, is the oil pressure port a metric pipe thread, or a standard 1/8" NPT like most other things?
Also, my father owns a B7200HST and it has a tachometer in the dash, along with an hourmeter. Mine has a hole in the dash panel for a 2 1/16" gauge, but the gauge itself isn't there. It just has a black plug. Was a tachometer not standard on the B6100E?
Much thanks for any insight.
Conn
   / New Guy...B6100E Aftermarket Gauge Install Qs.. #2
Probably just an hour meter like the b7100. I would like to add some gauges as well so I'll be following your thread ;)
   / New Guy...B6100E Aftermarket Gauge Install Qs.. #3
I owned a B6100E. That hole is for the optional hourmeter, no tach ever. Any 12v hourmeter will work. I had some surplus meters around at the time I bought mine and put one in my Kubota. Worked OK.
Vernon
   / New Guy...B6100E Aftermarket Gauge Install Qs.. #4
robj sent me a link to install temp gauge,its on this forum worked great,and the gauge does too
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
LEEBOY 8520 APHALT PAVER (A51242)
LEEBOY 8520 APHALT...
New Holland B95 Backhoe (A50490)
New Holland B95...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
