New Guy...B6100E Aftermarket Gauge Install Qs..
   / New Guy...B6100E Aftermarket Gauge Install Qs.. #1
Conn
Bronze Member
Garrard County, Kentucky
John Deere 6210
I recently aquired a B6100E with a 60" finish cut mower. The old girl needed some cylinder head work and is in the process of re-assembly at the moment with all new top end gaskets.
I want to add a water temperature and oil pressure gauge. I've located the oil pressure port, but can't seem to find a location to tap into the cooling system. Has anyone performed this task in the past and can you provide any information?
Also, is the oil pressure port a metric pipe thread, or a standard 1/8" NPT like most other things?
Also, my father owns a B7200HST and it has a tachometer in the dash, along with an hourmeter. Mine has a hole in the dash panel for a 2 1/16" gauge, but the gauge itself isn't there. It just has a black plug. Was a tachometer not standard on the B6100E?
Much thanks for any insight.
Conn
   / New Guy...B6100E Aftermarket Gauge Install Qs.. #2
Probably just an hour meter like the b7100. I would like to add some gauges as well so I'll be following your thread ;)
   / New Guy...B6100E Aftermarket Gauge Install Qs.. #3
I owned a B6100E. That hole is for the optional hourmeter, no tach ever. Any 12v hourmeter will work. I had some surplus meters around at the time I bought mine and put one in my Kubota. Worked OK.
Vernon
   / New Guy...B6100E Aftermarket Gauge Install Qs.. #4
robj sent me a link to install temp gauge,its on this forum worked great,and the gauge does too
71065 (A49346)
71065 (A49346)
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
STORAGE FEES (A51219)
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2010 LACROSSE LUXURY LITE TOURING EDITION TRAVEL TRAILER (A50854)
2010 LACROSSE...
71062 (A49346)
71062 (A49346)
