New Grapple exceeds expectations
   / New Grapple exceeds expectations
That's an awesome looking grapple !! Thanks for sharing the info ... One of these will likely be the first new implement I purchase when my L5740 comes in, sure will save a LOT of backaches...
Your welcome,
It is the sharing of information on this site that makes it easier for us to make a decision we can be satisfied with.
   / New Grapple exceeds expectations #52
It's funny, I have both the grapple, and QA forks, and I almost never use the forks. I had them on one time within the last year (probably more).
Interesting, I don't have a grapple and use the forks a lot however would like a grapple for brush. My forks have been very useful I just loaded my lawn tractor on the back of my pick up last week can't see doing that with the grapple, lol. Best wishes though and why not have it all;)
   / New Grapple exceeds expectations #53
Right. That is the beauty of quick attach.
   / New Grapple exceeds expectations #54
I use my forks for lifting on oil changes.
   / New Grapple exceeds expectations #55
I like how long the lower tines are, very nice for digging out brush roots. The only possible issue could be on heavy roots but that is where another style/size might work well.
I came across this thread while reaearching grapples for an upcoming purchase and your comment about the different style of grapples caught my eye. ANBO and also the WR Long root rake grapple both have an arc shaped rake, but most of the other brands use an "L" shaped rake (like Piston's in the picture he posted in post #42). What are the advantages and disadvantages of each style?
FWIW I'm looking for a grapple to clean up logging slash including some logs and also large stumps that were dug out with a dozer or excavator by the previous owner so he could food plots.
   / New Grapple exceeds expectations #56
Another nice grapple is found at the following web site.
Grapple
Company is owned by the Bo half of the Anbo company before it was bought out.
FWIW I'm looking for a grapple to clean up clear-cut slash including some logs and also large stumps that were dug out with a dozer or excavator by the previous owner so he could food plots.
Over the years I have heard many arguments here on TBN on the two different types of Grapples as well as the proper width. The advantages of the Anbo type style is the ability to back rake from fence lines. It also makes it easy to use some what like a dozer and get under the roots and pop them as you go. I have tore down a 50 foot carport with huge block covered with brick veneer columns. The grapple was so powerful it crushed the first column I picked up. So I was careful on the next one so I could move it in one piece. I piled the crushed wood in a pile and burned it. I can and have carried a lot with mine including from brush, trees, huge rocks,and washer and dryers. It can also pick up things a little as 3 inches. Piston can give you the pros of his style. Which I would think carrying large stacks of boards would be one of them. The claw style can carry things as well by rolling the grapple back. Both are good and depends a lot on the user and his creativity.
   / New Grapple exceeds expectations #58
Shane,
Nice grapple you have, I looked at these this week and may buy one for my 110tlb. Yours looks to be just about what I need. Have fun with it.
   / New Grapple exceeds expectations #59
I have a rake style similar to Kytractor's in this thread but with not as long of lower teeth. Mine is great for what I bought it for, grubbing and burning brush. But I can't pick up logs very well with it. I can, but I end up re-gripping a few times. Kytractor's Anbo looks like it can pick up logs much better than mine since his lower teeth are longer. The "L" shape lends itself to getting under logs and general debris. If you are going to dig out heavy roots, then narrow is better as the wider you go the more chance of stalling out. So it all depends on what you use it for.
Shane,
Thanks, The 110 Tlb would be a good match up for the Anbo Grs 72.
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51243)
(NEW) 2025 DOWN 2...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2015 INTERNATIONAL...
2013 Chevrolet Sonic Sedan (A50324)
2013 Chevrolet...
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
