New Grapple exceeds expectations
   / New Grapple exceeds expectations
Thanks guys the grapple was supposed to weigh 780 and came in about 860 according to the invoice
   / New Grapple exceeds expectations #12
An 860 lb. grapple sounds awfully heavy for a 45 hp tractor, but if you're happy with it, that's all that matters.
   / New Grapple exceeds expectations #13
That is heavy.
   / New Grapple exceeds expectations #14
Might be a bit heavy for my tractor which is a 45 horse as well but it seems to be working for you and that is what counts. I think my max loader lift is 2000 lbs but you have to remove all the weight of the implements and such, much like the payload of a pickup truck you have to remove the weight of tools, hitch and passengers from the payload, go figure.
No it's not too heavy at all.The Web site says 780 Lbs, The invoices says 880 Lbs. It could be a typo. It didn't fail too lift any thing that I tried it on including some pretty large trees that I thought might be trouble. My lift is close to 2900 Lbs. I accidentally hit some large rock in the ground harder than when I bent my Woods box blade shanks completely under. Thought for sure I messed up the grapple but I couldn't tell I hit anything. I would have hated to have to take it to a welding shop after the first day. So I'm glad I chose the heavier grapple. For my use I 'm extremely pleased with it.
Anbo also makes a 72 that is 370 Lbs that could be a better fit.
   / New Grapple exceeds expectations #17
How much KY?? I would like one very similar for my compact track loader.
   / New Grapple exceeds expectations #19
As long as your are a satisfied customer, that's what counts.
Suggest you have adequate counter weight at all times.
   / New Grapple exceeds expectations #20
Thanks! I'll have to look into getting one. That price isn't as high as I was expecting.
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
Hay Wagon (A50515)
Hay Wagon (A50515)
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
