New Grapple exceeds expectations
   / New Grapple exceeds expectations
Thanks guys the grapple was supposed to weigh 780 and came in about 860 according to the invoice
   / New Grapple exceeds expectations #12
An 860 lb. grapple sounds awfully heavy for a 45 hp tractor, but if you're happy with it, that's all that matters.
   / New Grapple exceeds expectations #13
That is heavy.
   / New Grapple exceeds expectations #14
Might be a bit heavy for my tractor which is a 45 horse as well but it seems to be working for you and that is what counts. I think my max loader lift is 2000 lbs but you have to remove all the weight of the implements and such, much like the payload of a pickup truck you have to remove the weight of tools, hitch and passengers from the payload, go figure.
No it's not too heavy at all.The Web site says 780 Lbs, The invoices says 880 Lbs. It could be a typo. It didn't fail too lift any thing that I tried it on including some pretty large trees that I thought might be trouble. My lift is close to 2900 Lbs. I accidentally hit some large rock in the ground harder than when I bent my Woods box blade shanks completely under. Thought for sure I messed up the grapple but I couldn't tell I hit anything. I would have hated to have to take it to a welding shop after the first day. So I'm glad I chose the heavier grapple. For my use I 'm extremely pleased with it.
Anbo also makes a 72 that is 370 Lbs that could be a better fit.
   / New Grapple exceeds expectations #17
How much KY?? I would like one very similar for my compact track loader.
   / New Grapple exceeds expectations #19
As long as your are a satisfied customer, that's what counts.
Suggest you have adequate counter weight at all times.
   / New Grapple exceeds expectations #20
Thanks! I'll have to look into getting one. That price isn't as high as I was expecting.
2022 JOHN DEERE 450K LGP CRAWLER DOZER (A51242)
2022 JOHN DEERE...
2015 Ford F150 Crew Cab Pickup (A50323)
2015 Ford F150...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2018 GENERAC MAGNUM PORTABLE S/A LIGHT TOWER (A51243)
2018 GENERAC...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
