New Garden, First Attempt at Plowing
/ New Garden, First Attempt at Plowing #21
when i set me 3 bottom up i had to turn my right side link if you sit on the tractor, out to cock the plow off to the side os i was in to faw or not enuf and it would also hit my 3 point arm also. i have a 03 jd 4510 hop it helps you i had to learn how adjust it the hard way and still don't have it just right.
Ok, well I got back out there and hooked up the plow, I'll make my observations:
I parked the tractor on the wood blocks, I see the right lift bar needed dropped more. Looks to me that the plow would leave about 4" between furrows the way it is now, but I could remedy this by moving my tires in to the next hole in the axles.
There is also an adjustment on the plow frame itself where I can move the bar that the lower arms attach to over, I think 1/4" equals 1" plow movement. Problem is the threads are gone due to rust, so I would have to be creative w/shims or something to make that work.
Looking at the frame of the plow, using the front bottom wouldn't work in this case. The plow would pretty much be directly behind the tire, or maybe a few inches inboard. I'm guessing this whole alignment is caused by it being a 2 bottom, designed for a much wider and taller (and more powerful) tractor.
Next, I have some questions about use that I didn't see covered.
It could still be in adjustment, but I noticed that, if I leave the lever in the float position, the plow will continue to bury itself to the top of the moldboard, until I just stop. It's been said that a 12" plow should turn 6" deep, is that on it's own or with controlled intervention?
The fact that I had to control the depth leads me to another issue: When the front tires go uphill, or the rear tires go down into a dip, the plow digs in more, creating another dip for the next pass. The opposite happens when the front tires are in a dip or the rears are on a rise. This makes for a lot of rowing on the lever. Additionally, I really don't react that fast, eye to hand.
I'm sure this isn't textbook, but what I ended up doing is multiple passes, from opposite directions, only taking say 4" at a time. After a few passes, I think I managed to get the high and low spots leveled off, and it plowed more smoothly. I've attached photos from between a few of the passes, and the last one is where I believe it's ready for tilling.
Comments and suggestions are welcomed, and thanks for the help so far!
Jim
/ New Garden, First Attempt at Plowing #25
The bottom edge of the share should be flat on the ground when you have the tractor up on the block. The tail wheel should be at or just below the surface of the ground when the share is flat on the ground. By your pics it looks like you have your top link too short which will make the plow dive quick, and that will be more difficult to control. If you have both left wheels up on blocks the plow should be adjusted level. If you only have the rear wheel up, then that would explain why the plow looks raised in the rear. If your tractor has Draft setting, use that rather than Position setting. If it doesn't, you have to keep your hand on the control lever and manually adjust it as it dives and surfaces. But if you get it leveled front to back it won't be so bad. Bottom line is that you need to control the depth. I find the correct depth and return the lever to that location as I start each row. My newer tractor does not have draft control so I have to keep my hand on the control lever, but it's only to make minor adjustments as I go.
But you got your soil turned, and you are ready to till now. That was your goal. If it stops raining you might get a chance to plant it by June. ;)
Thanks, that's exactly what I needed to hear. I think the problem I'm having with the top link is that this plow's frame is so high that I'm near the top of my 3pt's travel just hooking it up, so I shorten the top link to help it clear the ground while transporting. What I need to do in this case is to lengthen the top link every time I start a row to help the plow from diving in like it's doing. I was afraid of that, but your explanation cleared up all doubt.
Thanks!
Jim
/ New Garden, First Attempt at Plowing #27
I wanted to thank Dieseladdiction too for posting the youtube link. I thought it was interesting that the guy doing the video had to make a couple of adjustments during the video to get his plow adjusted like he wanted it. Thanks to everyone else, too, for the helpful suggestions. I got my garden roughly plowed this year before this thread got started, but I'm going to refer back to all these good suggestions before my next attempt at plowing.
/ New Garden, First Attempt at Plowing #28
I'm just glad it's not me holding onto the Troy-Bilt the first couple passes! Sure you can't borrow or rent a small disk to level things first? Save some muscles, for sure.
It's fun to learn about what you're doing as you go along, just the same.
Jim
Well, funny you should say that, because I got really lucky yesterday and picked up a rototiller! It's a Kubota FL1020, 42" I believe but I haven't measured it yet. The guy even gave me 3 suitcase weights. He threw a rod on his B7100 last year, sold the tractor but still had a few things for it.
I've been beaten up from a front tine tiller, borrowed a 9hp troybilt which was much nicer, but still heavy, hoping to be grinning from ear to ear while operating this one!:D
Jim
I couldn't agree more! I sat and read those 2 plow manuals over and over, thought I had it down. When plow hit dirt, all bets were off!
Jim
/ New Garden, First Attempt at Plowing #31
I snagged this 4' Tiller Saturday off of CL for $600. and it does a fantastic job! Worth every penny!
I can't believe how well it blends the soil, way better than a walk behind tiller.
/ New Garden, First Attempt at Plowing #32
i have that exact plow....just got it about 2 weeks ago.....haven't tried it yet but i have a feeling my results may be similar....
my FIL wanted a tiller, i found a used 74" bush hog for $800....he bought it:eek: so, i tilled up some of his ground the other day and planted some corn, green beans and taters.....i may till up more and plant more.....i've got the bug i just hope i get to eat some of it before the usual dry summer, bugs and birds feast on it!:rolleyes:
thanks for sharing.....
Now that you have a tiller the plow is not required!:D
It looks like you are right, Egon! I went out and tilled it up 3 times and it was looking good! Tilling Video
Reluctantly, I'll be putting this Dearborn back together to sell on Craigslist. I'm not sure if I should put a new shin, share, and coulter disk on the other bottom, or just sell it like it is.
It's surely for the best, even at a single bottom this thing is still too big for my B7100! I still want to plow, so I will be keeping my eyes out for a smaller plow.
Thanks for all the help,
Jim
/ New Garden, First Attempt at Plowing #34
yeah, two bottom plows don't seem to have a problem selling quickly on craigslist........
then, i'm sure you could pick up a nice single bottom that will match your tractor...
my soil wasn't nearly as dry as your's so i wound up with some clumps...i would have loved to let it dry out and then hit it again.....but, i had to get the stuff planted quickly....
Jim
/ New Garden, First Attempt at Plowing #35
Jim
I also used my plow for the first time this year to break some new ground. I have a smaller (40") tiller, but I find that it does not till deep enough to suit me. As a matter of fact it was after tilling that I decided to pursue a two bottom plow. The 2X14" plow I bought was well suited for my tractor (once I learned how to use it) and turned the soil over nicely. I ran the tiller over it after plowing and its pretty nice now.
I would recommend that you keep looking for the plow that fits your tractor. you should not have any trouble selling the one you have.
Your garden looks nice, time now to get some stuff planted:D
Mark
Oh, there's plenty of clumps. Trick photography!
I probably have another week to wait before the night temps are safe.
Are those brussel sprouts?
Jim
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
HOMEADE 8' X 22' TRI-AXLE TRAILER (A60430)
HOMEADE 8' X 22'...
UNUSED FUTURE DM39-39" HYD DISC MULCHER (A60432)
UNUSED FUTURE...
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
402 (A52706)
402 (A52706)
