New fronts on the Bobcat
   / New fronts on the Bobcat #11
Those rims look to be wider too. Doing a search I do find a 31x15.5-16.5 R4. They call for a 13" wide rim.
Edited to add: They're referred to as a 31x15.5-16.5 NHS I found them from Goodyear and Titan here http://titan-intl.com/files/Construction/TT110014_SkidsteerBroch_4.pdf. They're still a typical R4 tread pattern
I'd prefer 31x12 or 31x12.5's if I can find them since they'd fit on a rim designed for 12-16.5 tires. The search continues...
   / New fronts on the Bobcat #12
Here's his post, it's Hanson1999, a member on here
i had to get different rims. 15x10. easy to get as they are a standard ag 6 bolt pattern. the tires are 27x12.5-15 i got them on ebay.
Only use these if you have the larger r4 tires they won't work if you have 14" front wheels.
I love the wide fronts i don't think i'll be swapping back for any reason.
   / New fronts on the Bobcat #13
Thanks Cat. Those would be 3 1/2" (or more) less OD than typical 10-16.5's. I found 31x12.5's which would match the OD but they look to be pretty dang expensive.
2024 CHEVROLET SILVERADO 2500 HD BED (A58018)
2024 CHEVROLET...
19008 (A56859)
19008 (A56859)
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2024 Schulte 5026 Batwing Rotary Cutter (A56435)
2024 Schulte 5026...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
