New fronts on the Bobcat
   / New fronts on the Bobcat #11
Those rims look to be wider too. Doing a search I do find a 31x15.5-16.5 R4. They call for a 13" wide rim.
Edited to add: They're referred to as a 31x15.5-16.5 NHS I found them from Goodyear and Titan here http://titan-intl.com/files/Construction/TT110014_SkidsteerBroch_4.pdf. They're still a typical R4 tread pattern
I'd prefer 31x12 or 31x12.5's if I can find them since they'd fit on a rim designed for 12-16.5 tires. The search continues...
   / New fronts on the Bobcat #12
Here's his post, it's Hanson1999, a member on here
i had to get different rims. 15x10. easy to get as they are a standard ag 6 bolt pattern. the tires are 27x12.5-15 i got them on ebay.
Only use these if you have the larger r4 tires they won't work if you have 14" front wheels.
I love the wide fronts i don't think i'll be swapping back for any reason.
   / New fronts on the Bobcat #13
Thanks Cat. Those would be 3 1/2" (or more) less OD than typical 10-16.5's. I found 31x12.5's which would match the OD but they look to be pretty dang expensive.
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
2016 CATERPILLAR 262D SKID STEER (A52709)
2016 CATERPILLAR...
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
American G-Model Pump Jack (A56435)
American G-Model...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
