New from Ga with Ford 4000
/ New from Ga with Ford 4000 #1
johnwllms309
Ga
1967 Ford 4000
Just bought what is suppose to be a 1967 ford 4000 diesel with a 730 series 19-532 FEL, bigger than what I need and have a few questions for later. Never owned a tractor, but it was my favorite place to sleep as a kid when pop was plowing in the 70's in north Fl.
John
/ New from Ga with Ford 4000 #2
:welcome:
To TBN John. So, how much land and what are you doing with the new tractor? Where you at in GA?
Thanks for the welcome all. There is a lot of information/ knowledge here
mddorange-I only have 3.5 acres for now in Loganville, plan on cleaning up a few areas fence line that became a tree line, straighten out the drive, mow some, maybe garden some, also clean the old tractor up eventually making look/ operate like new.
/ New from Ga with Ford 4000 #7
Sounds like you have a lot of work to do. Did you get any implements with it? I used to live in Snellville back in the late 80's. Boy how things have changed over that way.
/ New from Ga with Ford 4000 #8
Welcome.
So what are your questions on that fine old workhorse?
/ New from Ga with Ford 4000 #9
Welcome to the forum.
:welcome:
Congrats on that new (to you) Ford!
Thanks for the welcome again all.
mddorange- Yeh this whole area has gotten out of control, the family moved here in the early 80's it's way different now. Hopefully the wife will move with me when I move way way way out LOL. Unfortunately I did not get any implements I am shopping though.
soundguy- right now she looks more like a warhorse than a work horse regardless it is a fine machine. Some of the questions are related to the model serial numbers, some technical found & spliced burnt wires , don't fully trust the cooling system yet gauge hits red pretty quick after splicing the wires( before nothing), more difficult steering right even with PS, PTO never stops even with the 2x4 test, need to dig into the FEL more. There are more but I want to gather my thoughts findings and search what is here then post in a more appropriate section of the forum ( Ford/New Holland?). A good place to find a shop & parts manual seem to be of the most important currently are the CD's or PDF's any good? or am I better off with the expensive hard copy? Epay?
It's funny the old Ford is like a time machine, I remember riding over the field with my go cart after pop plowed it poor go cart, and probably the most dangerous place I ever slept between him and the fender as he plowed. people would go to jail over that now LOL.
Thanks all New post to come with questions and pics.
John
/ New from Ga with Ford 4000 #11
on your 4000, on the bellhousing flat, aft of the starter will be the model ID and the sn. it may have a surviving foil tag ont he underside of the hood with dupe info as well.
pto issue.. is this a SOS 10spd machine? or a regular twin stick transmission?
It is a twin stick, I'll try to post some pictures later this week. If if my boss (wife) will let me I am going to order a manual as well, found a reprint on ebay for around 90 bucks doesn't seem too bad.
/ New from Ga with Ford 4000 #13
Pto staying engaged on those independent jobs coil be as bad as warped or piled up discs.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
20ft Deck - 4ft Dove Tail (A61166)
20ft Deck - 4ft...
New/Unused Wolverine 72in Quick Attach Tiller (A61166)
New/Unused...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
Wooden Rocking Chair (A61569)
Wooden Rocking...
2014 Mercedes-Benz C250 Sedan (A61569)
2014 Mercedes-Benz...
