New Forum software!!!! Like it or not??
   / New Forum software!!!! Like it or not?? #81
The only thing I miss is not being able to use a pull down to hit a specific forum section.
   / New Forum software!!!! Like it or not?? #82
jlesliel said:
This is what i get
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=269372"/>
Just wrap your search query in single(') or double(") quotes... 'pole barn' or "pole barn"
   / New Forum software!!!! Like it or not?? #83
How can I fix this jumble mess.
If I magnify, I can't see all the screen.
The page looked good before the upgrade.
Example:
   / New Forum software!!!! Like it or not?? #84
Example:
You are using Chrome on XP? Try disabling some plugins, here is what I get on Chrome in Windows 7:
Aaron Z
   / New Forum software!!!! Like it or not?? #85
Yes, am using Chrome on an XP computer.
I am not sure if your are saying that is good, or bad.
If the text size looks good on the top part, the post area is messed up, and if the post area looks good, the top is jumbled, as in my above post.. One will shrink and the other will expand.
I don't seem to balance things so everything looks good.
Is there a way to revert to the old TBN page display, which looked good to me in every respects.?
   / New Forum software!!!! Like it or not?? #86
Is there a way to revert to the old TBN page display, which looked good to me in every respects.?[/QUOTE]
I was trying to show that on my computer (as seen in the picture) everything is expanding in sync rather than in a jumbled fashion like you are seeing. My first guess would be that one of your plugins is messing with things.
As a troubleshooting step, could you try loading TBN in Chrome using "Private browsing mode" (hit Ctrl+Shift+N)? That will disable your plugins for the private browsing window and will let you see if one of the plugins is causing this.
I don't think that is possible as everything was upgraded.
Aaron Z
   / New Forum software!!!! Like it or not?? #87
The add on the right obscures the information on the right. If I make the browser window wider, the ad finally does not obscure info on the page.
I am using IE 8 on Windows 7.
   / New Forum software!!!! Like it or not?? #88
I like the ability to choose multiple files to upload in one step. That saves a lot of time when picking pictures to post on a thread.
   / New Forum software!!!! Like it or not?? #89
Example:
Your text size has been increased so much that it's making the formatting really bad. You should decrease your text size (control minus) once or twice for starters.
   / New Forum software!!!! Like it or not?? #90
Odd, I am running at 1280x1024 here at work and I can zoom in as far as Chrome 19.0.1084.56 m will let me (as seen below) and everything scales correctly. I also tried it at 800x600 with the same zoom level and it looked the same.
Aaron Z
2015 FREIGHTLINER CASCADIA (A50854)
2015 FREIGHTLINER...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
1972 Ford F600 Grain Truck (A51039)
1972 Ford F600...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
71064 (A49346)
71064 (A49346)
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
