New forks for my GC1705
   / New forks for my GC1705 #1
rider7767
Platinum Member
Paris, TN
TYM T264 with loader and implements
I received my bucket forks today from Titan Attachments. They seemed very well built and will surely be enough for my little tractor. I will chain them for heavy stuff. IMG_20161228_134327.jpgIMG_20161228_134334.jpgIMG_20161228_134358.jpgIMG_20161228_134414.jpg
   / New forks for my GC1705 #2
I got forks like that on ebay, very strong. Lifted my backhoe off of my truck with no problem.
   / New forks for my GC1705 #3
I just bought the same ones, mine came with the stabilizer.. I mostly use them for lifting logs so that I can chainsaw them into firewood..
   / New forks for my GC1705 #4
I nearly went this route but I questioned the stability of the forks when attached to the bucket like so and the fact that u lose some lifting power. But I use mine with pallets and cutting firewood. Do you guys find that they don't move around on you. Im just wondering even though i went a different route.
They seem stable. I bought these to move small stuff around. I would not want to lift more than 500lbs in this setup. I don't want to bend my bucket. I have seen pictures where people have bent there buckets trying to use these like a forklift attachment.
   / New forks for my GC1705 #6
good point as i had forgotten about that as well.
   / New forks for my GC1705 #7
Mine don't move when I use a pipe to tighten them and use the stabilizer. I wouldn't try to lift anymore than 500lb's either, I'm not afraid of anything bending but I am afraid of snapping my front axle..
   / New forks for my GC1705 #8
I used mine to lift an old wood burning stove that must have weighted 700 lbs. It worked fine and the tractor had no problem lifting the load. I have added some bucket reinforcement so I'm not worried about bending anything.
I use the forks for so many things, sometimes they get more work than anything else.
I think mine will too. I have needed them many times before buying them. They are easy to take on and off.
That axle is very strong, but I stay on the safe side too.
HARDEE RD72M LOT NUMBER 154 (A53084)
HARDEE RD72M LOT...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
Hay Spear for Tractor (A51573)
Hay Spear for...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
