New Fence
/ New Fence #1
anojones
WA
JD 3320
I've been working on fence to define the yard and keep in the dogs, took some tractor time and resulted in a new PHD. This first picture is digging the post holes with the JD 3320.
/ New Fence
Here the posts are being set- that little yellow thing is a level for setting posts- best $5 I've spent in a long time.
/ New Fence
I attatched the 2X4 welded wire using this tool- it ain't cheap but it sure beat hammering in fence staples. It has a battery that sparks a aerosolized fuel cylinder to fire 16 gauge galvanized staples. It worked really well.
/ New Fence
Here's the post, rail and wire with the post tops still running randomly.
/ New Fence
And the finished product.
/ New Fence
It's the new treated lumber- which looks pretty nice and is left as is. I have a few of the posts that have been in the ground for other reasons and it seems to hold up pretty well. The stuff is extra green- which makes it heavy but hopefully heavy duty as well.
Aaron
/ New Fence #8
Nice! Top rail looks nice and smooth, even on the slope.
My forearms and wrists would've killed for that automatic staple gun a couple days ago. /forums/images/graemlins/smile.gif
/ New Fence #10
Very nice fence. What size auger did you use for the post holes? I have not used a PHD before but am considering one for my own project. Did you set the posts in concrete?
/ New Fence
Thanks for the nice comments on the fence. It wasn't easy getting the rails just right- I first just did them level with step downs but ended up removing them and doing it by eye to best match the slope of the ground (trial and error).
I didn't use concrete, I did add gravel to each hole for drainage. I was concerned if I wanted to remove the fence that dealing with the concrete would be a pain- also the infill is wire, which is much lighter then a wood infill and allows the wind to blow through. Tamping is a painful job, but the posts seem quite stable.
I used a 9" auger on the PHD- I have an underground sprinkler system and the posts went between a mainline and a sprinker line so I couldn't safely dig a bigger hole. It also meant less hole to fill in. A 12" would be more forgiving when you dig a hole that's off center of not quite straight (which happens all the time). If you do buy a PHD- keep in mind a lot of companies make a smaller one to fit subcuts that digs about 36"- the regular size one will dig to about 42"- if your tractor will handle it, the bigger one would be better. It's a great implement and I'll be digging some holes for trees soon as well.
/ New Fence #12
That's good information. I've set a few posts using rock, and they are very stable. We will be replacing several hundred feet of barbed wire on our place (~19 acres). Barbed wire is not good with horses. My tractor will work well with the larger PHD (Mahindra 6000). I'm planting trees as well, so yet another reason to purchase.
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
County Line 4' 3Pt Mower (A66408)
County Line 4' 3Pt...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
New Electric Scooter (A65579)
New Electric...
