New Fence Finally Going Up.
   / New Fence Finally Going Up. #21
High tensile wire is too light for brace wire. Use #9.
   / New Fence Finally Going Up. #23
That is just plain bad information. That's all I've ever used, double wrapped on a long pull, single wrapped on a short pull.
Of all the things I've had to replace when fixing fence I have built, my brace wires were never one of them.
And BTW we tighten woven wire with a tractor.
   / New Fence Finally Going Up. #24
Nice fence. Looking forward to watching your progress as you post more pics.
What brand of fence wire are you using, Agriman? The label looks like it says Stay-Tuf?
All in all do you think a driver much better/easier than a post hole digger?
Yes Sir! No doubt about it, even an old driver is better than an post hole digger. Especially the manual kind.
   / New Fence Finally Going Up. #26
I have always used #9 for brace wire. I do not know the gauge of high tensile. I have always strung woven wire.
Hi tensile wire is 12.5 gauge and 200k psi rated.
#9 brace wire is 9 gauge and 40k psi rated.
   / New Fence Finally Going Up. #28
That doesn't sound right.
Give me a minute to switch to my lap top and I'll provide a link.
***EDIT***
210,000 PSI, 12.5 gauge high-tensile wire
I'm still looking for the #9 tensile strength.
***EDIT PART2***
I cant seem to find a rating on just the brace wire. The only thing I can find is a woven wire with #9 top and bottom wires. Those are rated at 70K PSI.
   / New Fence Finally Going Up. #29
What driver do you use?
   / New Fence Finally Going Up. #30
***EDIT***
***EDIT PART2***
You have 12.5 gauge wire rated higher than 9 gauge wire. #9 is heavier than 12.5 gauge.
1999-2010 Ford Pickup Truck Bed (A49461)
1999-2010 Ford...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
