New Explorer
/ New Explorer #1
Bedlam
Ford and Kiotie
I downloaded the new explorer. its free.
And I wasnt sure if id like it or not but its great once you get used to it.
One thing thats good is the tabs, it allows you to have more things open in one box.
one "trouble' I had, was everytime I opened explorer, it would open a seperate tab with the yahoo news.
(PITA)
Anyway if you get there and have the same problem. go to tools and internet options. I found that I had two "home" pages one yahoo and the other yahoo news. I deleted the yahoo news and added the addy for TBN.
So now when I open the explorer, I get yahoo. AND TBN very convient.
Now to work out my troubles with i spell
Allan
/ New Explorer #2
I "downloaded" it last week quite by accident....I wasn't paying good attention during a windows update. So far I hate it. Don't like not being able to put the URL part of the menu on the lowest level (it seems locked at the top of the page) and I don't know what happened, but my email (I use Outlook Express) seems to be randomly NOT downloading attacments/pictures from some email since the change. I don't understand why IE 7 should impact that, but the timing of both is identical. In general, I think the tabs feature may end up being nice for reducing task bar clutter, but I just don't like the different presentation of the menu bars.
Change is always bad. Always. ;)
/ New Explorer #3
firefox has had the tabs thing for quite a while now and the most recent update has spell check built in. Firefox is my preference.
/ New Explorer
I am sure there is a way to go back. I know I did nit a week ago, after I didnt like it. Im not sure where, but I searched it and downloaded the older version.
Im no expert but have to learn lol.
Maybe some one here will be able to help you.
good luck.
Allan
/ New Explorer #5
I'd like the new IE7 if it would work right for me. I still have it installed hoping Microsoft releases a patch for it, but I'm not holding my breath. If you want to remove IE7 and go back to IE6 open Control Panel. Go to Add/Remove Programs and scroll down til you see Windows Internet Explorer 7. Select it and then click Remove.
/ New Explorer #6
I use SeaMonkey by Mozilla which is where FireFox comes from. Anything Mozilla is better than Microsoft.
/ New Explorer #7
I downloaded IE7 on my laptop that I use for school. Had several problems with it and have already removed it and am back to IE6. JayC is correct, just remove IE7 following his directions and your computer should automatically default back to IE6.
/ New Explorer #9
IE7 is one of the reasons I don't like Automatic Updates turned on. I prefer to decide for myself what updates I install. I would be pretty mad to turn the computer on one day and find IE7 sitting there. Even if IE7 worked properly for me, I don't think I could go back to having that as my default browser. I've been using Firefox since version 1.0.3 and with the extensions available, it really is the best choice for me. I've been checking the Microsoft newsgroup for IE hoping there will be mention of a patch or something. My problems are probably not as common, but I am not the only one with these problems.
Sounds like you downloaded the Yahoo version of IE7. As much as I like Yahoo, I still prefer the standard MS version. Essentially they are the same except for a few things Yahoo bundles with it. With the Yahoo version you get the Yahoo toolbar (not to fond of it), the two home pages that you already mentiomed, and a whole slew of search options on the search box next to the address bar. I have never been a fan of toolbars. They just use more space on the screen and really don't make things any easier.
/ New Explorer #10
IF you did as I did, and "removed" IE 7 via the control panel, you may be in for some unpleasant surprises. I got locked out trying to make some last minute online trades with Fidelity.com, and eventually got someone in their website help department....too late to make my trades for the day btw:mad: . Guy was very helpful, said they have been inundated with calls...apparently it is all but impossible to COMPLETELY remove IE 7, and using add/remove programs does not do it. He showed me (ok, led me to) some components of IE 7 that remained embedded in the IE 6 I "reverted" to. These components cause rips in the time/space continuum;) , and other effects such as causing some links to not work or not work properly. The link(s) to preview and complete a trade on Fidelity's website are among those that no longer work when this happens. Forewarned is forearmed.
/ New Explorer #11
It just gets worse....we use Quickbooks Pro 2005, and this morning I went to enter info. Turns out QB 2005 will NOT work with IE 7, and the QB site documents this. Unfortunately, they tell you to just remove IE 7, and I already know that is not a complete cure...it may allow QB 2005 to work, but it leaves ghosts in the machine that create other IE problems. This may end up being a clean reinstall of the OS if I find too many more such problems.
/ New Explorer #12
I also downloaded it through auto updates but it did give me the option , kind of snuck it in, but I decided to try it, I had it for 10 minutes and I hated it, like yahoo it wants to take too much control. I went to control panel and deleted all of its components, now back to the way I like it, working for me, not me putting up with it.. John
/ New Explorer #13
If you have system restore active, Windows should have created a restore point prior to installing IE7. If so, you can completely remove it by by going Start > All Programs > Accessories > System Tools > System Restore and picking a point prior to IE7 installation.
/ New Explorer #14
I had installed it in the Beta version, and didn't like it. I used the restore feature to eliminate it from my computer. Doubt that I will go back.
/ New Explorer #15
So I would have thought too. According to the tech at Fidelity, IE 7 is apparently a bit more insidious than that. I have done both....the "remove prgoram" route, and the "restore" route. Both apparently leave some components of IE 7, or the update that was done when it came on board. I am trying to ensure that we don't download it on our other PCs, and I just won't be able to use QB and perhaps some other things on this one PC.
/ New Explorer #16
I have Firefox and IE installed. I only use IE for one particular site that I use for work. Firefox is not supported on that site, but for everything else I use Firefox. The improvement with Firefox is night and day difference. I read about the problems with the new IE earlier in the week and turned auto update off. Not unusual for Microsoft to put something out that has not been tested fully yet. Just throwing out new software and fixing it with patch after patch is not acceptable to me.
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
2024 Kubota RTVX1140 (A64127)
2024 Kubota...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
Bush Hog 18ft. Disc (A65640)
Bush Hog 18ft...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
John Deere Silage Wagon (A65640)
John Deere Silage...
