New equipment
/ New equipment
”I took delivery today of the first new tractor I’ve ever owned. It is a Kioti CK3520SE HST Cab. It has the KL4030C FEL with a 66” bucket . I also bought a set of 2000 lb forks and the KG2060 grapple. I had RimGuard added to the rear tires. I also bought a hydraulic top and side link. The top and side link aren’t installed yet. I went with the R14T tires. Really excited to finally get a piece of equipment that isn’t already worn out“
We love our 2005 CK25 HST 1270 hrs.
I was wondering if the oil filter has been protected? Years ago ran over something that ripped the filter off and broke the housing. 🤬
The oil filter is above the frame rail and behind the front axle, so it looks fairly well protected.
/ New equipment #22
Yes, the top link is installed. I used it today with my box blade and it works well for fine tuning the angle. The side link is still on order. I’ve used the grapple to pull out some roots after I ground a couple of stumps. I was very happy with how it worked.
/ New equipment #23
That's a real nice setup; great machine, good attachments, you're going to have a lot of fun getting things done.
Congratulations on your new tractor, she's a beauty. For my use grading roads that slow moving triangle would have to relocate. First tree branch would hook it and tear it off. Guessing it's mounted there due to rear mounted fuel tank?
It's mounted there on cab models; on the open station the SMV sits to the lower left.
/ New equipment
Thank you!
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
Caterpillar 20'' Backhoe Bucket (A60463)
Caterpillar 20''...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
(20) 2.5cm X2M Ratchet Straps (A60463)
(20) 2.5cm X2M...
2005 John Deere 7420 (A60462)
2005 John Deere...
2019 DITCH WITCH FX25 PORTABLE VACUUM TRAILER (A59823)
2019 DITCH WITCH...
