New equipment tie down....
   / New equipment tie down.... #1
Big Bri
Platinum Member
Kubota MX5100
While taking my Kid to school this morning we came across this. The strap is pretty bad but it's also a light duty trailer, with 3500 lb axles. They were driving 65 to 70 down a 4 lane hwy in rush hr traffic.
Well I got a new phone and it must not be compatible with tbn as it doesn't allow me to up load any photos. Find that hard to be leave...maybe it's just operator error. I have an iPhone what am I doing wrong.
Had to email the photos to myself and upload from the computer. . . i miss my droid.
enjoy
   / New equipment tie down.... #4
If you are using the TBN app (rather than accessing TBN from a browser,) to add a photo click on the '+' in the upper right of the screen next to the 'Send' button.
wasn't using the app. never had to on the droid. guess i'll have to try that on this phone because i could not upload a photo to a craigslist add last week ether. Thanks for the advice.
   / New equipment tie down.... #6
Hmm, the only thing that strap is gonna do is prevent the skid steer from sliding backwards off the trailer. What happens though if the driver stops fast? :confused2::confused: I also couldn't help but notice that his track is loose, if he lets it be the sprocket will eventually put unnecessary wear on the lugs in the tracks. :confused2: All I can say is i am glad that wasn't my skid steer on that trailer, mine gets strapped down with several chains and binders. :thumbsup::)
   / New equipment tie down.... #7
I'm a retired truck driver with lots of flat bed and some low boy experience. The rule is pretty much that the load needs to stay put in the trailer under all driving conditions. That's my wording, not the law's.
That driver in your photo would not need to use any additional securement if the skid steer would fight tightly in the trailer on all sides as long as the trailer is sturdy enough to handle the driving conditions and, of course, the truck and trailer are legal in all other respects. You do not need to strap, chain, etc. your load if it will not shift. It is not required that the load be secured enough to stay on the hauling vehicle if it rolls over into a ditch, etc. but it better stay in place if he has a 'typical' fender bender. Load shifting is prohibited.
The pictured trailer and load has several obvious problems. The sides are marginal appearing as far as sturdiness, marginal as to whether they are high enough to keep the skid steer from tipping out on a hard turn, and obviously the machine doesn't fit tightly in the trailer so it does need to be chained or strapped properly. Clearly no knots except for tarps and other load coverings as long as the coverings do not shift.
   / New equipment tie down.... #8
Great app. The only thing I wish it had was more member info like that shown on the web page access like location, total posts, etc. You can click on the posters icon but the info provided is limited Otherwise it is probably the best app of its type.
Edit: it does show total posts. My bad. Now my only complaint is lack of location info.
in Louisiana you have to have all equipment chained on 4 corners and all buckets have to be chained down as well. he is not even close to being legal here. You are right the trailer was way to light, the wheels were tilted inward and the tires were riding on the edge of the tread.
   / New equipment tie down.... #10
Interesting because I hauled my mini-excavator from Minnesota to Missouri in my dump trailer. There was no good way to tie it down because the top of the tracks are about even with the sides. I loaded it forward so the blade was against the front wall. Then I lowered the bucket against the tailgate so it was locked in place. I questioned MN, IA, & MO DOT. What do I need to secure it? Answer was that chains are required on flatbeds, but in my case since the load was locked in place by the sides, no chaining was necessary. I did run one 3/8" chain over the tracks and the only solid piece of steel on the track frame that was above the tracks even though they said it was not needed because you never know how a trooper might interpret the rules. It would likely have stayed in the trailer in a roll-over, but there was absolutely no way to chain 4 corners like I do when I haul it on my flatbed. I think I met all the rules that retired trucker said. At Caterpillar we designed our smallest compactors with 4 tie-down points but almost all leave the factory with truckers running one heavy strap over either the articulation joint or across the operator platform. Our shipping department just records how they are tied down on departure - the method used is truckers discretion and responsibility.
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
2018 Jeep Grand Cherokee SUV (A51694)
2018 Jeep Grand...
1263 (A50490)
1263 (A50490)
