New Driveway
/ New Driveway #1
Bigboyskioti
Just thought I'd tell you all about my new adventure. About 4 years ago I let a man talk me into laying blacktop down for my drive. I had planned to use concrete but this seemed so much easier. Anyway shortly after he had finished my drive had holes forming and it got worse as time went on. After many calls to this guy & the lawyer, we have decided to tear it out and do it right. The drive is 600' long with a 32' x 35' parking area, we have also decided to include the "barn lot" this time around. I have talked to many people about tearing out the blacktop. Now you may ask how does this pertain to tractors? Well after having a severe case of sticker shock from the loader guys I thought why not try the Kioti.... My litle CK20hst is doing a great job (I told the wife we needed the loader). This little tractor is amazing. It's peeling up sheets of this junk like nothing. I removed around 5 tons in about 2.5 hours last night. I'll post some pics over the weekend.
/ New Driveway #2
I came close to getting the CK20 too, great heavy little tractor.
/ New Driveway #3
Don't waste that old asphalt. Put it somewhere it can be broken up, spread and repacked.:D
/ New Driveway
The CK weighs in around 3000lbs FEL & BB through in another 230 for the operator. And yes it's a great machine so far. It does whatever I ask of it.
The bigger peices are being put in a low spot next to the drive then will be covered. The smallers ones will be used on the drive. This is actually fun work. The wife thinks I'm crazy.
/ New Driveway #6
I wouldn't have tore all that base up. i'd have cold patched the bad areas.. or limed and tar'd them.. or at least concreted them.. and then I'd have put my new surface course right over top of it. Less work, and should last longer for less money.. etc.
soundguy
/ New Driveway
Ended up only removing around 150' of the drive. It had buckled up so bad from being thick on the edges around 6" to only around a half towards the middle. We were worried that there was some pumping going on in the this section. The ground underneath is packed great and now we have no worries about the concrete staying put. All of the parking pad has been removed because we wanted the concrete about 1" lower than the floor of the garage. I had planned on putting some pics up but ran out of time the last few days. If I weren't at work (paying job) I'd be working at home right now..... All that is left is preping around the barn. That section only had gravel. I'll get pictures up tomorrow night.
/ New Driveway #8
I have a driveway of similar (600') length, and am considering whether to asphalt or concrete. Concrete is about $80/yd here, so I imagine would cost $25K for concrete based on 12' width (13k concrete and 12K for labor). But I haven't obtained any bids from contractors. I am curious what the concrete driveway will cost you, if you care to share?
/ New Driveway #9
You've heard of garbage in, garbage out, well that goes with asphalt also.
If you have a bad base you will continue to have problems. If you are not 100% sure about the base, you will only add to the problem.
Tear it all up redo the base compact the base and do it right.
/ New Driveway
I had bids from 35K to 22K just concrete and labor. Since the building industry is at a low in my area I was able to "talk" a couple of these guys down a tad. The final cost will be around 21K with steel, crete, labor, any gravel that is needed. Concrete is running me 81 a yard with fiber, that's a 6 bag mix and some say 4000 some say 5000 pound mix..... Used to be a 6 bag mix was 5000, so who knows.
The base wasn't the problem. I had 8 yard loads of concrete in the trucks drive up my gravel road without a dent. The this blacktop was put down and it crumbled. I found out why when I tore it out. Some pieces were 6" some were only .5". Guess where it crumbled?
/ New Driveway #12
While we aren't there to see the extent of the problems.. the way he was describing the asphalt coming up it really sounde dlike a scabbing problem.. and / or adhesion. Sounds like the original contractor crowned it wrong and left too thin a surface course.. and/or didn't tack coat the base before laying the first course.. etc. vs a failure of the base.. etc.
soundguy
/ New Driveway
The contractor never put a base layer down. I'm much wiser now on how to put balcktop down. The reaserch should have been done before hiring anybody but.... The way I see it now is that a base layer should have been placed down using modified base blacktop. He also never put the tachcoat down at all. The gravel drive that was there for 6 years prior to all this had thousands of tons of gravel on it. Started with 500 tons of #2's then went to 57's(1") then went to dense grade (lime stone crushed). As stated we had 8 yard loads of concrete on this drive and it never moved. There was a crown like it's supposed to be but this guy didn't do a good job at all!
/ New Driveway #14
Yep.. preferably.. it would have ben boxed out, had stabilized subgrade.. compacted finish grade of a suitable materiallike sandy clay, limerock, or reclaimed concrete / asphalt, then tack coat, then surface coarse of asphalt.. etc..
without a stabilized subgrade.. everything above it is useless..
soundguy
/ New Driveway #15
Lifting Asphalt is always easy! ain't nothing going to make it stick to the sub grade!:D
Sounds like the previous fellow was working with an excellent sub grade but did not have a grader to get the sub grade level and even so an even layer pf asphalt could be laid down.:D :D
/ New Driveway
Thought you guys might want an update on the driveway.... They started pouring the new drive this past Monday. Some of these pics show just how steep my drive is. The one with the mixer I took that as the truck was coming back down his left front tire was 20" off the ground. scared me more than the driver..... I just told the guy I've never had anybody hurt on my jobs and didn't want him to be the first. This drive looks fantastic! Well hre's the pics of what's been done so far.
<table style="width:194px;"><tr><td align="center" style="height:194px;background:url(http://picasaweb.google.com/f/img/transparent_album_background.gif) no-repeat left"><a href="http://picasaweb.google.com/Bigboyskioti/NewConcreteDriveOCT07"><img src="http://lh5.google.com/Bigboyskioti/RwaM0YUGyTE/AAAAAAAAAOQ/QcyRhLYJGsE/s160-c/NewConcreteDriveOCT07.jpg" width="160" height="160" style="margin:1px 0 0 4px;"></a></td></tr><tr><td style="text-align:center;font-family:arial,sans-serif;font-size:11px"><a href="http://picasaweb.google.com/Bigboyskioti/NewConcreteDriveOCT07" style="color:#4D4D4D;font-weight:bold;text-decoration:none;">New Concrete Drive OCT 07</a></td></tr></table>
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
3142 (A63117)
3142 (A63117)
INTERNATIONAL 5300 END WHEEL GRAIN DRILL (A64278)
INTERNATIONAL 5300...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
