New DK5010SE Rear tire valves
   / New DK5010SE Rear tire valves #1
skipples
Somis, CA
Kioti CK35 HST, Kioti DK5310SE HST
They're on the inside???
   / New DK5010SE Rear tire valves #2
They're on the inside on mine (2022 DK5310SE)
   / New DK5010SE Rear tire valves #4
Thanks. Just checking.
No worries, it was kinda comical when the delivery driver was going over the basics when he dropped it off and we got to tire pressure; "So here are your front stems, all nice and protected, and your tires are filled, and as we move back here, your rear stems are ...... uhh.... oh, ..... sorry, so if ya look through the rim right here, you can see that little fellar on the back side, and I apologize, I don't make em', I just haul em'." 😅
   / New DK5010SE Rear tire valves #5
If you swap the tires, the valves will be on the outside.
   / New DK5010SE Rear tire valves #6
And the tread will be backwards.
   / New DK5010SE Rear tire valves #7
Swapping them mean left to right, not just spinning them around.
   / New DK5010SE Rear tire valves #8
Depends on your rims, many of the turf, R4 and R14 are one piece rims that can not be flipped. So if moved from one side of the tractor to the other while maintaining the same side to the outside will result in reversing the tread.
   / New DK5010SE Rear tire valves #9
Just picked up a DK4720SE and mine are on the inside too. I was wiping down the inside of the wheel and as the rag hit the air valve, I heard air escape... they never tightened the valve. It was loose And all fluids were at minimum.
My biggest complaint so far is the location of the oil fill plug (hard to get to) and covered by wires. Poor design.
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
