New DK5010SE Rear tire valves
   / New DK5010SE Rear tire valves #1
skipples
Somis, CA
Kioti CK35 HST, Kioti DK5310SE HST
They're on the inside???
   / New DK5010SE Rear tire valves #2
They're on the inside on mine (2022 DK5310SE)
   / New DK5010SE Rear tire valves #4
Thanks. Just checking.
No worries, it was kinda comical when the delivery driver was going over the basics when he dropped it off and we got to tire pressure; "So here are your front stems, all nice and protected, and your tires are filled, and as we move back here, your rear stems are ...... uhh.... oh, ..... sorry, so if ya look through the rim right here, you can see that little fellar on the back side, and I apologize, I don't make em', I just haul em'." 😅
   / New DK5010SE Rear tire valves #5
If you swap the tires, the valves will be on the outside.
   / New DK5010SE Rear tire valves #6
And the tread will be backwards.
   / New DK5010SE Rear tire valves #7
Swapping them mean left to right, not just spinning them around.
   / New DK5010SE Rear tire valves #8
Depends on your rims, many of the turf, R4 and R14 are one piece rims that can not be flipped. So if moved from one side of the tractor to the other while maintaining the same side to the outside will result in reversing the tread.
   / New DK5010SE Rear tire valves #9
Just picked up a DK4720SE and mine are on the inside too. I was wiping down the inside of the wheel and as the rag hit the air valve, I heard air escape... they never tightened the valve. It was loose And all fluids were at minimum.
My biggest complaint so far is the location of the oil fill plug (hard to get to) and covered by wires. Poor design.
378490 (A51573)
378490 (A51573)
2012 L3 MEP-806B GENERATOR (A52576)
2012 L3 MEP-806B...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
