New Diamond C HDT
   / New Diamond C HDT #1
Tractorable
Marshall, Va
Tractorless, 2019 Toyota Tundra, 1980 Toyota Land Cruiser FJ40
Special ordered a new 24ft Diamond C Hydraulically Dampened Tilt equipment trailer a few months ago and picked it up last week.
Options: 12K pop-up winch, 16ft tilt with 8ft stationary, dual 7K axles, 12 D-rings, full length stake pocket rub rail, 3/16” heavy duty fenders, solar charger, 12K jack, 8” I-beam construction, bed roller for winch line.
The tilt deck can be hydraulically locked up or down with a valve.
I had it de-rated from 14,900 GVWR to 14,699 GVWR to come in a pound under 26K GCVWR with my 11,300 GVWR F350. Weighs 4510lbs empty, 10,190 payload.
   / New Diamond C HDT #4
Really nice 👍
Never saw a pop up winch.
   / New Diamond C HDT #5
What a monster! Looks like a well-designed trailer. (y)
   / New Diamond C HDT #6
That is a super nice trailer, really like the set back axles. It will be easy to adjust the load for hitch weight. One thing I do question, is the stake pockets need spaced out from being counter sunk into the I-beam. Don't look like a 2x4 will fit.
   / New Diamond C HDT #7
I have one of the older designs of HDT. Mine is 24 foot, (6 foot stationary), with the locking toolbox up front.
Question...using the winch to load a vehicle with the ramp down what method is used for the cable to slide over the lifted ramp? Pulley or some sort of Teflon/metal slide? I have thought about adding a winch to mine.
   / New Diamond C HDT #8
That is a very nice trailer. EXCELLENT choice.
It has:
Toolbox
Place for Spare Tire
Hydraulic cylinder for locking and lowering.
Recessed winch - interesting idea. Looks really good. Would like to know how that works out after a year or so.
Stake pockets
Rub rail
Deck tiedowns - Not sure I would want those. But handy. I might have to park tractor on one.
LED lights - Add a few more.
Front jack looks setback somewhat - good.
Tilts where it should. With separate bed. also nice.
One of the best-looking trailers I have seen.
Only one question. It has everything else, when will you add an electric drive to the front jack??
Congratulations - nice.
   / New Diamond C HDT #9
Wow, thats a slick trailer, congrats.
One question though, what good is a winch if you can't use it when the deck is tilted? Like, how would you use that winch to pull a dead vehicle on, on the side of the road somewhere? Also what keeps the winch from just trying to close its hatch under load?
   / New Diamond C HDT #10
He does mention a "deck roller".
Sweet trailer 👍
What's did the empty weight come in at?
20ft Driveway Entrance Gate with 2 Columns (A57454)
20ft Driveway...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
1453 (A57192)
1453 (A57192)
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
