New Cub Cadet Owner 7305
   / New Cub Cadet Owner 7305 #1
Beezer1
Opelika, AL
Cub Cadet 7305
Thank you in advance for your web site I can see already it will help me with my newest yard toy, Cub Cadet 7305 with Front loader and back box blade. I live in Opelika AL and my wife and my self operate a small Tool and Die shop on our property.
I earned the Tractor by offering to fix the windowed block mess that had been sitting Idle and in boxes for 4 years.
The block was easy for me to fix and I restored the 200 hour almost new tractor to operational in about 40 hours worth of work.
I still have one issue that has stuimped me. When I attach the front end loader it works perfect but the rear three point will not raise up unless I bump the front end loader. Then it will raise up to the position I had previously moved the depth gage hadle to. I thought I may have had a diverter valve issue so I turned the spool over 180 degrees and it changed nothing. When the front end loader is unplugged from the diverter valve the rear 3 point works as normal no issues.
Has any one else had similar issues with this tractor?
Thank you,
Beezer1
   / New Cub Cadet Owner 7305 #2
Welcome to TBN. :)
Galvanized Steel Fence 10ft x 7ft (A55758)
Galvanized Steel...
2013 Cadillac ATS Sedan (A55758)
2013 Cadillac ATS...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
2021 PETERBILT 389 SLEEPER (A55745)
2021 PETERBILT 389...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
