New Cub Cadet Owner 7305
   / New Cub Cadet Owner 7305 #1
Beezer1
Opelika, AL
Cub Cadet 7305
Thank you in advance for your web site I can see already it will help me with my newest yard toy, Cub Cadet 7305 with Front loader and back box blade. I live in Opelika AL and my wife and my self operate a small Tool and Die shop on our property.
I earned the Tractor by offering to fix the windowed block mess that had been sitting Idle and in boxes for 4 years.
The block was easy for me to fix and I restored the 200 hour almost new tractor to operational in about 40 hours worth of work.
I still have one issue that has stuimped me. When I attach the front end loader it works perfect but the rear three point will not raise up unless I bump the front end loader. Then it will raise up to the position I had previously moved the depth gage hadle to. I thought I may have had a diverter valve issue so I turned the spool over 180 degrees and it changed nothing. When the front end loader is unplugged from the diverter valve the rear 3 point works as normal no issues.
Has any one else had similar issues with this tractor?
Thank you,
Beezer1
   / New Cub Cadet Owner 7305 #2
Welcome to TBN. :)
RoGator RG1100C (A52128)
RoGator RG1100C...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2021 TAKEUCHI TL6R SKID STEER (A51242)
2021 TAKEUCHI TL6R...
