New BX25?
/ New BX25? #21
EmerichSales said:
I don't think we will see them until October. There has been an extra Dealer incentive for the last 2 months on the current BX's. Right Now is a great time to buy the current BX. I really don't know if there will be any other incentives coming out? I don't think so.
The New BX25TLB will be based on the BX24
Same D902 Engine but they are listing the PTO HP at .2hp greater than the BX24.
BX25TLB
23 Gross HP
17.7 PTO HP
Same RPM's
increased top speed to 8.4mph from 8.1
Same Loader and BackHoe
Kevin
Emerich Sales & Service inc.
Will it be like the BX2660 with a hoe or more like the BX24. Metal fenders and hood? Different hydro w/o the neck snap in reverse, seat?
If not I see no reason to wait get a BX24 or a BX2660 and put on a woods BH
/ New BX25? #23
The advantages in the BX2660 would be that bit of extra hp and the 20% larger radiator. There are two disadvantages. One is the extra $1500 it would cost to put the Woods bh on instead of going with the BX25 (it costs to retrofit the hydraulics, seat, take off wheels, etc., to get to frame, properly bolt/torque subframe to mainframe, etc. et. al.). One more little disadvantage to the Woods BH6000 is that when you have the 3ph lift arms at full lift, you cannot also have them at full spread, and at full spread, you cannot have them at full lift. The ends of the 3ph lift arms hit the upper coupling points on the 4ph for the backhoe subframe. Scrounger (Matt) has some pics of this in the archives, and mine does the same thing. I think I am going to be able to solve this little problem with an angle grinder, however, by shaving a bit of the "ears" off.
/ New BX25? #24
EmerichSales said:
It will be like the BX24
I am curious, did they give any particular reasons for going with the 902 instead of the higher rpm version of the 1005 now on the BX2660? (The D1005 on the B2320 puts out 23 HP gross at 2800 RPM, as opposed to same block on BX2660 putting out 26 hp at 3200 RPM. D902 seems to be rated 23 hp at 3200 RPM.) Same question for apparently staying with the same radiator instead of the new 20% larger radiator on the BX2660? Have there been any engine problems with the higher rpm version of the 1005 on the BX2660 that made them nix it in favor of the 902?
/ New BX25? #25
Who knows, You may see a BX26 or BX27 coming. They will introduce next years product in Sept.
Kevin
/ New BX25? #27
Neil,
Are you starting trouble? You know you can't mention a BX125. That could flood the market with used BX22, BX23 and BX24s as the horsepower hungry SCUT faithful await the BX with 125HP. Only reason it really ticks me off is that it would kill the value of my BX24, which by the way is powerful enough. If you want 125HP, buy a car.
/ New BX25? #28
asylum575 said:
Neil,
BX24s as the horsepower hungry SCUT faithful await the BX with 125HP. .
I dont know, mowing at 45 mph sounds pretty good to me..... Will those come with GPS remote controlled auto pilot so that once you mow an area, it will retrace its tracks in the future eliminating the need for a driver?
/ New BX25? #29
The seat really should be leather. A cab with airconditionong and a sunroof would complete the package.
And to think I was happy that my TLB could be used as a mower. Such low expectations I set for my equipment.
Maybe I'l throw a flowmaster on and dual out the pipes.
See what you started Neil.
/ New BX25? #30
Yea sorry... you guys are amazingly fast with this stuff. The info that started this thread must have been word of mouth, because the offical bullitin only came out today.
/ New BX25? #31
Tom
If you buy a bx2660 and add a woods hoe wouldn't you have the best of both worlds?
The new hydro and metal parts and seat would be nice. Power is not the issue for me.
Why would they make a bx25 and not change anything?
/ New BX25? #32
I was at a dealer last week and I was told the new models are coming out to meet new emission requirements. They also fixed a few things that folks had been complaining about (ie. Seat, plastic hood and hst hard stopping).
/ New BX25? #33
Kevin is saying its going to be like the BX24 not he new BX2660
/ New BX25?
Hmmm....all your responses have been very helpful - thanks. Sounds like it's going to be the D902 engine with emission control additions - part of me wants to rush out and buy the one without those, and the other part wants to have a greener tractor. A big part of getting a tractor is to help with my pretty bad back problems - I read about a snappy HST in changing directions and I wonder if the improved one is worth waiting for to reduce the pressure on my back. What do you BX24 owners think? My dealer still seems to think he can get me a new BX25 in July or August - but he seemed to think it would be based on the D1005.... hmmm. He should have the dealer announcement now though. If I had to wait until October or later I would probably get the BX24 rather than lose the summer with it. Be nice to have a seat that turned round as easy as possible and locked in smoothly. Plastic fenders - there seem to be pros and cons enough for them to not be a deciding factor.
I'll make my mind up next week....
/ New BX25? #35
Petethenomad said:
Here is a link:
Kubota Canada : Manufacturer of compact diesel tractors, construction equipment, agricultural equipment, power washers and engines.
I have a dealer spec sheet, dated June 5th 2008, here:
-redesigned HST, smoother changes in direction
-Metal hood and fenders
-better seat - as found on Grand L40
-allows loader to move at engine idle
-25.5hp D1005 engine
Dealer here expected it to be 1200-1500 canadian dollars more than the BX24.
Pete
Thats a spec sheet for a BX2660 not a BX25
/ New BX25? #36
The BX25 will have the D902-E2BX2 Kubota diesel with 23 Gross HP and 17.7 PTO HP
Kevin
/ New BX25? #37
Roadkill95 said:
Tom
Except that it would cost more and the 3ph arms hit the 4ph for the bh when at full width/full lift. Some do believe that the Woods bh is a tiny bit stronger than the Kubota bh. When I dig in dry clay or hardpan, the hoe throws the tractor all over the place. (And that is with FEL and stabilizers are all down.)
/ New BX25? #38
I hear you loud and clear on this issue. Getting old stinks, but it is better than the alternative. I personally don't have any problems with the HST and changing directions. Just like driving a car, some people stomp one pedal then stomp the other, while other people know how to ease off of one and ease onto the other.
The place you are more likely to pull a back muscle or slip a disc is in changing implements. I have all of mine on dollies. We have a 3 car garage with each bay a bit deeper than average. The 2 cars each take up a space and the 3rd is for the tractor and implements. When time to change implements, the 2 cars back out to make room for rolling everything around. I custom built all of my dollies myself to make each implement move in the easiest manner possible. Even at 800 lb. the backhoe moves right up to its 4ph and I can make minute allignment adjustments with the push of a couple of fingers. Implements that sit outside on the ground can be a bear to get alligned and attached; dollies on smooth flat pavement makes all the difference in the world. Another advantage to the BX here is that a subcompact tractor takes implements that are smaller than a compact or bigger tractor, thus reducung the weight you have to handle.
/ New BX25? #40
shownuff said:
i dont want to mix and match different pieces to make up the unit i want it together from kubota
There have been many TBN members who have put a Woods bh on their tractors. Other than the cost and this minor hitch issue, there have been only positive reports about the BH6000. Many members believe that the Woods BH70X and BH80X are superior to the Kubota BH75 on Kubota B series tractors. There are many other attachments you might wind up using on the three point hitch of your tractor, and Kubota only makes a very few of them. Woods, Gearmore, and other manufacturers build some fine pieces of machinery that attach to tractors. I have attachments built by many other companies that work very well on my Kubota tractor. For me, the name Kubota represents quality, but there are others whose quality is just as good. And, BTW, Kubota dealers usually sell these other brands and usually will be quite honest with you regarding whether another company's attachment will work better and is more cost effective than the Kubota version.
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
(2) UNUSED 27X8.50-15 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2018 Ford Focus Sedan (A61574)
2018 Ford Focus...
UNUSED ATSPOWER 40 GALLON AIR COMPRESSOR (A64281)
UNUSED ATSPOWER 40...
