This is a new machine, what if the SUCTION STRAINER for the hydraulic pump is partially clogged from debris left in the passages during machining and assembly. Also the Front End Loader can have air pockets in it that do not work out until someone starts using it. My BX1860D had a dirty strainer. I pulled it and cleaned it to clear some of the issues described! Then refilled the hydraulics. Check the oil level with the bucket closer to travel position, not on the ground, also have the MMM in the up position, and the 3 pt hitch raised. This will give you a more accurate level on the hydraulic reservoir. You may be sucking in AIR!
