Rotary Cutter New Bush Hog Chain guard necessary???
   / New Bush Hog Chain guard necessary??? #31
I too recommend chain guards or the like.
You just never know what you'll really be cutting, especially if you infrequently.
There is one 2 acre meadow I mow only once each year. Every time I manage to throw rocks or log shrapnel when I cut that meadow. I made a set for my Howse using old chain. It was pretty easy to fab a mount and cut the chains to length. I would've bought a set of chains from Howse, but the shipping was equal to the chain cost. So for me it was a no brainer to make them myself.
Here is the thread with lots of photos: Add Chain Guards to Rotary Cutter
There were a lot of good ideas thrown in from the TBN guys.
Rob-
   / New Bush Hog Chain guard necessary??? #32
Nice job on the guard Rob. Did you size every one of those links to fit over the bar and weld those small ends to the bar??? :eek: Nice job if that's what you did. But.....lotsa work...no? I took the easy route.....and just laid the whole chain link on the side and welded the loops. I simply held them in place with with spring clamps. I'm not as good of a welder as you are.
I may add a rear chain guard next winter if time permits. I didn't originally think it to be a problem....but, it seems as though someone (usually my wife or a friend) is always approaching me as I work......and I worry I am going to throw junk at them.
   / New Bush Hog Chain guard necessary??? #33
I am fixing to make a set of chain guards for the used Bush Hog I just got. I have had wood thrown into the tire and punch a hole in it at our hunting club. I will always have a guard on any thing I use from now on.
Jim
   / New Bush Hog Chain guard necessary??? #34
Is the hay roller belts tough enough for a guard on the back. I put chains on the front but they would be a bit tougher to fabricate on the rear.
   / New Bush Hog Chain guard necessary??? #35
Yes.. bailer belting should work.. so will conveyor belting.. or truck mudflaps. I made the front guards on my hog out of cheap 4$ truck mudflaps, andle iron.. drilled holes and cheap bolts..
works great..
soundguy
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
