New Branson Models
/ New Branson Models #1
Lindsay, OK
Kubota B7100
Sometime next year, possibly early spring, Branson will be releasing the all new 40 Series. It will have three models from 75 to 95 horsepower. I don't have very many details yet. But, that won't be too bad if they get up to that big in 10 years on the US market. Heck, it took Kubota 3 times longer. Anyhoo, Monday should bring further details for those interested.
Well, so far no more news on the bigger models, but heres a little something to look at in the mean time. Its the new Branson 2400. Im guessing its 24hp but i have no other info as of yet. It will be at the National Farm Machinery Show and the Tulare Show this month.
/ New Branson Models #5
Glad to see that they may be moving away from those side covers that are such a pain in the rear end to take off to get access under the hood....but in 2 yrs, that is the only complaint that I have with the tractor....wish I could say the same with all the other vehicles I've owned.....Brian
/ New Branson Models #6
Besides the apparent feature of floating above the turf, I like the headlamps being up above the FEL level. Does anyone know of a replacement grill that raises the lights on our 10 & 20 series? Any other solution besides ROPS lights?
The 2400 looks like a very nice tractor. Looking forward to seeing how the specs compare to the 10 series. Let us know if there comes any more info.
As far as I know there isnt any kind of restyled grill available. Y'all be the first to know when the specs start flowing.
This on is going to be a little lengthy since the scanner wont cooperate. Here are the specs on the 2400(24HP). There will also be a 2100(21HP) and 2700(27HP).
Dimensions(with R4 Tires)
-Length = 111"
-Width = 53"
-Height = 92"
-Wheelbase = 59'
-Front Tread = 33.6"
-Rear Tread = 34.6"
-Ground Clearance = 12"
-Weight = #1,958
Engine
-Combustion System = Swirl Chamber
-Aspriation = Natural
-Perfromance = 24HP @ 2600 RPM
-No. of Cyl. = 3
-Displacement = 1175cc
-Fuel Type = Diesel
-Fuel Cap. = 6.07Gal.(23L)
-Air Cleaner = Dry element
PTO
-PTO HP = 22HP
-Rear PTO Speeds = 540/960
-Mid PTO Speeds = 2500
Steering
-Hydrostatic
Clutch
-Dry, Single plate
Brakes
-Mechanical Wet Disc
Transmission
-Mechanical
-6F/2R
-Hydrostat
-Dual Range
Tires(R4)
-Front = 12x8.5-12
-Rear = 12-16.5
Hydraulics
-Hitch = Cat. 1
-Pump Flow = 8.3 GPM
2006 Ford F-350 4x4 Ext. Cab Reading Service Truck (A66736)
2006 Ford F-350...
2016 FORD F-150 (A67714)
2016 FORD F-150...
2018 Rotary SM18N001 18,000lb. Hydraulic 4-Post Auto Lift (A66736)
2018 Rotary...
2016 CHEVROLET IMPALA LIMITED CAR (A66091)
2016 CHEVROLET...
2002 STERLING L7500 SINGLE AXLE BEVERAGE BODY TRUCK (A69167)
2002 STERLING...
2014 Caterpillar 304E Mini Excavator (A66734)
2014 Caterpillar...
