New battery
/ New battery #1
starbrightsteve
wellsboro,PA
l2800 Kubota
I have an L2800 that I bought new in the spring of 2006. It still has the original battery and it still starts. I used it to push snow the other day and it had been sitting for two months but it started right up. Any suggestions on where to get another good battery?
/ New battery #2
On previous posts your subject came up and the usual spectrum of possibilities were posted. In my case, I just bought the Walmart Everstart Maxx @ $120. ...Group size 51R. That brand has gotten good comparative reviews.
/ New battery #3
In my opinion, the absolute best bang for the buck is an Walmart Everstart Maxx battery, but you should not really expect it to be normal to get 14 years out of any battery by any manufacturer.
/ New battery #4
I just bought a Group 27 starting battery from a local dealer that sells his branded/labelled batteries made by EASTPEN (Never heard of them) and he says generally 3-5 years is the life of the average battery. When you get old, that's like the blink of an eye! I kind of ended up buying the battery based on weight!
/ New battery #5
I don't recommend Interstate will last like this because I've had a few that were no better than any others . I have over 30 battery's to maintain only 7 are less than 10 years old and two in my forklift need replacing some are 12. This battery came out of my dump truck 5 years ago still holds a charge and used at my mill to run a hydraulic toe board.
During the winter when my battery's sit , once a mon. I put them on a battery minder ( tender ?) for 3 or 4 days that's suppose to desulfate them and fully charge them maybe it helps no way of me proving it.
/ New battery #6
Starting batteries are much improved from years past, and it is not unusual for one to last 10 years or beyond, absent abuse.
Lately, I've been buying Deka batteries but I have had good luck with other brands as well.
That said, it is possible to get a less than good one from anyone.
SDT
/ New battery #7
11 years so far on the BX battery (knock on wood...) I'm convinced that keeping an inexpensive smart battery maintainer - which I have on _everything_ that sits for any length of time - makes a major difference.
Z.
/ New battery #8
I've still never been convinced
I got 11 years from my original tractor battery
13 years from my last truck battery (truck can set unused for weeks at a time)
9 years from my original motorcycle battery (original battery still worked, but seemed to be getting weaker) (typically sets unused from mid Oct -Early April)
Non ever had a battery tender on them
/ New battery #10
East Penn is one of the major USA battery manufacturers.
They make NAPA batteries, Deka batteries, and a host of other brand names.
Exide makes Everstart (Walmart), Interstate, and others.
Johnson Controls makes Duralast, Optima, and others.
/ New battery #11
Also Have L2800 but 09 and has original battery and it still starts.
Winter time I plug in the heater to help battery on cold start ups.
Previous Kubota battery lasted 14 years try so call brand name it just hold up so I bought Kubota battery work like charm and better fix in the battery box....check Kubota battery prices etc.
/ New battery #12
/ New battery
Does anyone out there think or know if the batteries sold by the Kubota dealer are worth buying. I知 talking about original equipment Kubota batteries. I realize that Kubota May have cut corners in the last 14 years but maybe not.
/ New battery #14
coleman equipment Kubota/Interstate Battery Group 24 575 CCA
Item #77700-00450
In Stock $121.53
/ New battery #15
They are probably good. But how much do they cost? I liked the Idea of putting a John Deere Battery in my Deere. Bought the tractor new. To me that matters a little bit. Keeping my John Deere, all John Deere, that kind of thing.
/ New battery #16
John Deere does not make batteries. They are just relabeled batteries from another manufacturer.
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A61165)
2007 Ford F-450...
2013 Kubota RTV1140 4x4 Diesel Utility Cart (A61567)
2013 Kubota...
UNUSED WOLVERINE M-SB42 42" MINI ROCK BKT (A62131)
UNUSED WOLVERINE...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
SCAN TO RECEIVE TEXT UPDATES (A62131)
SCAN TO RECEIVE...
