New B7800 = B3200
/ New B7800 = B3200 #1
jambx
Southern CT
B2920 TLB, ZD21-60P, 1949 US Baird Beaver
I have been looking to upgrade from my BX22 to possibly a B2920 or B3030 however, I just dont like the current B3030 BH design (with additional seat) and was just informed that our friends at Kubota have incorporated the B2920 integrated swivel seat and a new BH :) with the the B7800 replacement called the B3200 (which is due out this November).
Anyone heard anymore on this new model?
/ New B7800 = B3200 #2
I've only heard rumor, but the 7800's replacement will be similar to the 2X20 series tractors with the updated sheetmetal along with the updated items like the loader valve under the seat. I assume it will still have the added wheelbase of the current 7800. It should be a great tractor !
/ New B7800 = B3200 #3
Just wondering how much of a burden you think the dual seat setup would be to you. I was in the same predicament when I began shopping for a new machine. I had only ever run TLB's, from the BX22 all the way up to full size backhoes, all with the single seat. I had a real "problem" with the dual seat setup of the B3030, until I started thinking about all the time I spent rotating the seat on the TLB's.
It came down to the way I use a TLB, and it happens that a large portion of my particular use consists of moving back and forth between the tractor and the backhoe quite a bit. I remember often times thinking swiveling the seat around all the time was a real pain when I was jumping back and forth a lot. It turns out that after logging 135 hours on my B3030, I prefer the dual seat setup - at most, I only have to flip the 2 seats up or down (if I don't want the sun to heat them up too much), and there's no messing with the seat linkage in twisting the seat around and moving into the raised backhoe position or lowered tractor position, and making sure the mechanism locks every time so the seat doesn't flip out of position when you get up. In cooler weather, I can leave both seats down in position and just hop on and off.
One other thing to pay attention to is this new backhoe - be sure it is at least 7.5' and specs out at least as strong as the BH75. I wouldn't want anything smaller or less powerful - the BH75 is matched nicely to the B3030 and B7800.
Good luck and happy tractor shopping! :cool:
/ New B7800 = B3200 #4
I thought I was the only one that preferred the dual seat setup.
Originally, I thought that a single seat setup would be ideal, but after using a B21 for three weeks I realized the dual seat setup was much more convenient.
Vic
2018 Kawasaki 4x4 Diesel Utility Cart (A66734)
2018 Kawasaki 4x4...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
2004 (INOPERABLE) INTERNATIONAL TRANSTAR 8600 (A67714)
2004 (INOPERABLE)...
2018 FORD F-250 SUPER DUTY PLATINUM (A67714)
2018 FORD F-250...
HONDA generator (A64553)
HONDA generator...
