Loader New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff
   / New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff #11
I like those hooks. Any idea if they would fit a B2320 LA304 Bucket?
Good question... go to a Kubota dealer and compare the 'lip' on the buckets of both the B and BX. Sorry I'm on the road at the moment and I don't even know the bucket model # of my BX. It might happen to be the same... at least the upper lip profile. A quick call to BXpanded will answer it too. They are great to deal with.
   / New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff #12
I easily mounted bolt-on grab hooks on the bucket of my Kubota B3300SU.
Ken's Hooks are the highest quality and come complete with Grade 8 nuts/bolts/washers. Chain grab hooks NEVER move.
Ken's Bolt on Grab Hooks <<Bolt-On>>
Here's how I moved an 11ft Pine Log Bench. (see pics). This one was much lighter than the full log I moved earlier. No pic on that. I have a Skid Steer type Bob-Tach quick disconnect bucket & loader and I need to be careful if I weld hooks on it. I also probably should have used a larger set of straps.View attachment 391584 View attachment 391583
   / New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff #14
   / New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff #15
We used my neighbors B3300 and chains to lift our new home generator into place, no problem. When I dropped my FJR1300 a couple of weeks ago, I used straps on the FEL to pick it up. I don't see a problem if things are balanced and you take it easy.
   / New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff #16
I welded on 5/16 grab hooks as they work with 1/4, 5/16, and 3/8 chain, one on each side of the loader to bucket attach points - 4 total. Also reinforced the center lip of the bucket and installed a 2" receiver hitch*. The hitch can hold a 2" recovery hook (gotta be careful pulling with nylon strap though, as they can make like a rubber band if they break. The receiver hitch is also handy for moving empty trailers. I made a drop down hitch for this to get the trailer ball or pintle hitch low enough. Having a bucket camera makes trailer hook ups a snap, as you otherwise can't see the hitch as you approach the trailer.
*This would preclude using most bucket mount grapples I've seen, but if I need a grapple I'll buy a separate one as my B3350 has SSQA.
bumper
   / New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff #17
I'll bet the manual on the BIG excavators says the same thing.
   / New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff #19
I recently took a forklift training class. The instructor told us that in the next few years, if straps or chains are used to pick something, a crane certified operator will be needed
   / New B2650 manal says do'nt put chains, rope or strapes on loader to lift stuff #20
Maybe I should read my manual? :laughing:
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2005 FORD CROWN VICTORIA (A58214)
2005 FORD CROWN...
MAYTAG BRANOS XL WASHING MACHINE (A58376)
MAYTAG BRANOS XL...
2011 TROXELL 130 BBL STEEL (A58214)
2011 TROXELL 130...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2017 Chevrolet...
