New attachment - flush hydraulic oil?
   / New attachment - flush hydraulic oil? #1
cold1313
Northern, Ohio
Kubota M4D-071 Kubota F3990
I have a new implement coming in, with two hydraulic cylinders.
Should I flush / drain out the oil that comes in the cylinders, to not contaminate my Kubota hydraulic oil?
   / New attachment - flush hydraulic oil? #2
If it's new the cylinders should be clean (and are unlikely to contain oil).
If it's used, then there could be nasty watery old oil in them. You can disconnect hoses, drain the cylinders and inspect the oil.
It's brand new but has been cycle tested at the factory, so it will have some sort of hydro oil in it
   / New attachment - flush hydraulic oil? #4
I would not think there would be enough fluid to cause any issues. I would just use it.
   / New attachment - flush hydraulic oil? #5
I would (and have) for used cylinders. Haven't bothered on new cylinders. Factories should be testing with reasonably clean decent oil. I'd likely even do it on a rental impliment.
May be overkill, but a couple bucks of oil & 15 minutes of my time is worth the piece of mind. Even if dirty oil isnt actually going to cause any problems. It doesn't take much to mess up a HST tranny.
Right...I know it's overkill but I'm tempted to open the quick connect fittings and try to manually cycle the cylinders to see if I can get any foreign oil out of it. Overkill but was worth asking before I just plug and play.
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A52472)
2013 TEXAS PRIDE...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2013 RAM 4500 (A50323)
2001 MACK RD688S (A52472)
2001 MACK RD688S...
